Hi all,
We dont see LDAP Authentication menu under Admin > Manager Users section. Could you please advise on why this could be missing?
Enviroment:
RHEL 7 OS
Offline install - Fusion v4.0.0
Regards,
Hari Kandati
Re: LDAP Authentication menu
Do you see LDAP/AD Integration listed under Admin > Manage Components?
Can you try upgrading to the latest?
Thanks, dont see LDAP config under Manage Compoents. Attached the screenshot.
If this is known issue v4, yep will for the upgrade
The AD/LDAP component was added in 4.1.0 - https://www.nagios.com/downloads/nagios ... hange-log/.
Thanks..! Will plan for the upgrade. Post could be locked
great!kandatih wrote:Thanks..! Will plan for the upgrade. Post could be locked
Locking
