CHECK_NRPE: Receive header underflow
RIDS_I2MP
Post by RIDS_I2MP »
Hello Team,
We have one AIX server whcih we have been monitoring from a long time, all he services were monitored properly through our Nagios XI.
Not sure why, the services went into UNKNOWN status and we are getting below error for all of them:
CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
[nagios@eu2napu003 ~]$ /usr/local/nagios/libexec/check_nrpe -H 10.147.109.107
NRPE v2.12
[nagios@eu2napu003 ~]$ /usr/local/nagios/libexec/check_nrpe -V
NRPE Plugin for Nagios
Version: 3.2.1
eu2napu003 - Nagios XI server
Remote host: 10.147.109.107
Please check and help us to resolve this issue.
Thanks & Regards,
I2MP Team.
benjaminsmith
Re: CHECK_NRPE: Receive header underflow
Post by benjaminsmith »
Hello @RIDS_I2MP,
Did you make any changes to either the XI server or AIX server recently?
Please run of those those checks from the command line on the Nagios XI server, however, use the -2 option for version 2 packets, and post the output to the thread.
For example,
/usr/local/nagios/libexec/check_nrpe -2 -H remote-host check_command
Reference:
Nagios XI - How To Test Check Commands From The Command-line
RIDS_I2MP
Post by RIDS_I2MP »
I have ran test check from command line and getting the same output for all of them.
[nagios@eu2napu003 ~]$ /usr/local/nagios/libexec/check_nrpe -2 -H 10.147.109.107 check_disk
NRPE v2.12
[nagios@eu2napu003 ~]$ ^C
[nagios@eu2napu003 ~]$ /usr/local/nagios/libexec/check_nrpe -H 10.147.109.107 check_disk
NRPE v2.12
[nagios@eu2napu003 ~]$ /usr/local/nagios/libexec/check_nrpe -2 -H 10.147.109.107 check_services
NRPE v2.12
[nagios@eu2napu003 ~]$ /usr/local/nagios/libexec/check_nrpe -2 -H 10.147.109.107 check_cpu_custom
NRPE v2.12
There was a failover activity on last weekend in which this server was also present, we are not sure if any changes were made.
Thanks & Regards,
I2MP Team.
Actually, the correct syntax is to use "-c" to pass the command, e.g.:
./check_nrpe -H <client ip> -c <command>
so try:
/usr/local/nagios/libexec/check_nrpe -2 -H 10.147.109.107 -c check_disk
/usr/local/nagios/libexec/check_nrpe -2 -H 10.147.109.107 -c check_services
/usr/local/nagios/libexec/check_nrpe -2 -H 10.147.109.107 -c check_cpu_custom
RIDS_I2MP
Post by RIDS_I2MP »
[nagios@eu2napu003 libexec]$ /usr/local/nagios/libexec/check_nrpe -2 -H 10.147.109.107 -c check_cpu_custom
CPU OK - 112.3% CPU out of entitlement|cpu_ent=112%;;;0;300
[nagios@eu2napu003 libexec]$ /usr/local/nagios/libexec/check_nrpe -2 -H 10.147.109.107 -c check_disk -a '-w 15% -c 10% -p /home'
[nagios@eu2napu003 libexec]$ /usr/local/nagios/libexec/check_nrpe -2 -H 10.147.109.107 -c check_disk -a '-w 13% -c 5% -p /u02'
[nagios@eu2napu003 libexec]$ /usr/local/nagios/libexec/check_nrpe -2 -H 10.147.109.107 -c check_services -a 'syslogd'
Thanks & Regards,
I2MP Team.
The problem seems to be with passing arguments. When you installed NRPE on the client, did you enable command arguments?
Example:
./configure --enable-command-args
Even if you set up:
dont_blame_nrpe=1
in the nrpe.cfg, passing arguments would not work, unless you compiled the agent with --enable-command-args.
RIDS_I2MP
Post by RIDS_I2MP »
We have set the below value in nrpe.cfg file:
dont_blame_nrpe=1
But, did not enable the below:
Please let me know what am I supposed to do now?
Thanks & Regards,
I2MP Team.
RIDS_I2MP wrote:But, did not enable the below:
You would then need to re-compile NRPE from source with that configure flag
RIDS_I2MP
Post by RIDS_I2MP »
I tried running that but getting below error:
NON-PROD> [email protected]: /usr/local/nagios/etc > ./configure --enable-command-args
ksh: ./configure: not found.
Thanks & Regards,
I2MP Team.
You need to download the package and be in that directory when you run it
https://support.nagios.com/kb/article.php?id=8
