Hi, I've just built a Nagios system on
Ubuntu and want to do 2 things.
1. Monitor some windoze boxes on my net and
2. Monitor the printers/routers
I tried to install the windows agent but it barfed saying that I needed a 32 bit msi (even though that's on the label) and also I need to have net-snmp and net-snmp-utils but they don't exist in the libexec directory. My version is 1.4.11.
Thanks for any feedback.
j
Windows monitoring
Re: Windows monitoring
Which windows agent are you trying to use? I'm also not sure what net-snmp and net-snmp-utils has to do with windows. I recommend using NSClient++ as your windows agent.
Hello, I do not know if this topic has already been addressed or is not the right place to treat it.
I downloaded the check_exit_status.pl, and monitor nagios where I have my machine (localhost) and it works perfectly, the problem is when I check a remote machine. The error that throws me is "Check the output or exit status of a script." I check the script but I see you have the option-H HOSTADDRESS not know if I would have to be set or something. Thanks hope can help
Would you be able to post this as a new topic just for visibility purposes, when you do so are you able to provide a link to the plugin you downloaded?
