Remove ack
bosecorp
Remove ack
Post by bosecorp »
Hi
is there an easy way to do mass remove acknowledgement instead of doing one by one. I manage to remove all the coments, but I know I need to remove all the ack
Re: Remove ack
There is no way to remove acks in bulk in the GUI, at least not yet. You could try removing them from the command line by running:
service nagios stop
sed -i 's/problem_has_been_acknowledged=.*/problem_has_been_acknowledged=0/g' /usr/local/nagios/var/retention.dat
service nagios start
Let us know if this helped.
bosecorp
Re: Remove ack
Post by bosecorp »
worked. thanks a lot
Re: Remove ack
I am glad I could help! :)
