WebSphere monitoring using Nagios
mgangumolu
Post by mgangumolu »
Hi Team,
I installed nagios, plugin on nagios servers and plugin and nrpe on client server. From Nagios console, I can view basic checks status like disk, ping, ssh. My requirement is to monitoring websphere / Jboss on a remote system from Nagios Server. I have gone through internet and couldn't find right steps to implementing monitoring. Could you please give the steps / links which i can follow to setup.
Thanks in advance.
Maruti.
Re: WebSphere monitoring using Nagios
If you were using Nagios XI I would just point you to the one of the easy wizards that do this, but in core the plugin you would likely want to use is check_jvm
https://exchange.nagios.org/directory/P ... vm/details
