Upgrade from 5.5.9 to 5.6.3 fails
Sampath.Basireddy
Post by Sampath.Basireddy »
Hi There,
Am trying to upgrade our NagiosXI instance from 5.5.9 to 5.6.3.
When I run ./upgrade, it gives below output:
[root@nxip01 nagiosxi]# ./upgrade
error: rpmdb: BDB0113 Thread/process 30897/140484928223296 failed: BDB1507 Thread died in Berkeley DB library
error: db5 error(-30973) from dbenv->failchk: BDB0087 DB_RUNRECOVERY: Fatal error, run database recovery
error: cannot open Packages index using db5 -  (-30973)
error: cannot open Packages database in /var/lib/rpm
ERROR: Could not determine OS. Please make sure lsb_release is installed or your OS info is in /etc/os-release.
Please suggest.
Re: Upgrade from 5.5.9 to 5.6.3 fails
This sounds like your server is having a problem with it's yum database, here is an article outlining how to resolve it
https://www.ostechnix.com/solve-error-r ... or-centos/
Sampath.Basireddy
Thank You @scottwilkerson.
That helped, am able to run yum successfully now.
Is it safe to close this topic or you have more questions/issues?
Sampath.Basireddy
Yes, please close this topic.
Thank You
