Example
Host1 10
Host2 5
Host3 7
etc
etc
Host1 10
Host2 5
Host3 7
etc
etc
echo "select name1 as host, count(*) as service_count from nagios_objects where is_active=1 AND objecttype_id=2 group by name1;"|mysql -pnagiosxi nagiosCode: Select all
echo "SELECT * FROM tbl_service INTO OUTFILE '/var/lib/mysql/services.csv' FIELDS ENCLOSED BY '"' TERMINATED BY ';' ESCAPED BY '"'
LINES TERMINATED BY '\r\n';" | mysql -u root -p nagiosxi nagiosql
curl -XGET "http://<ip address>/nagiosxi/api/v1/config/service?apikey=youkeynumber&pretty=1"
I got the following errorsscottwilkerson wrote:you can do this in SQL
ERROR 1045 (28000): Access denied for user 'nagios'@'localhost' (using password: YES)
echo "select name1 as host, count(*) as service_count from nagios_objects where is_active=1 AND objecttype_id=2 group by name1;"| mysql --user=root --password=nagiosxi --host=localhost --database nagios
The sql statement provided does not workbenjaminsmith wrote:Hi @rajasegar,
The services configurations are stored in the nagiosql database in the table named tbl_services. You can dump this table to a spreadsheet and then sort by host and find the number of services for each host.
For example:Alternatively, you can use the backend API to get a listing of all the services in json format. Go to Help > API Docs.Code: Select all
echo "SELECT * FROM tbl_service INTO OUTFILE '/var/lib/mysql/services.csv' FIELDS ENCLOSED BY '"' TERMINATED BY ';' ESCAPED BY '"' LINES TERMINATED BY '\r\n';" | mysql -u root -p nagiosxi nagiosql
For example:Code: Select all
SELECT * FROM tbl_service INTO OUTFILE '/var/lib/mysql/services.csv' FIELDS ENCLOSED BY ' TERMINATED BY
-bash: ESCAPED BY ' LINES TERMINATED BY '\r\n';: command not found
mysql Ver 14.14 Distrib 5.1.73, for redhat-linux-gnu (x86_64) using readline 5.1
Copyright (c) 2000, 2013, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Usage: mysql [OPTIONS] [database]
-?, --help Display this help and exit.
-I, --help Synonym for -?
--auto-rehash Enable automatic rehashing. One doesn't need to use
'rehash' to get table and field completion, but startup
and reconnecting may take a longer time. Disable with
--disable-auto-rehash.
-A, --no-auto-rehash
No automatic rehashing. One has to use 'rehash' to get
table and field completion. This gives a quicker start of
mysql and disables rehashing on reconnect.
-B, --batch Don't use history file. Disable interactive behavior.
(Enables --silent.)
--character-sets-dir=name
Directory for character set files.
--column-type-info Display column type information.
-c, --comments Preserve comments. Send comments to the server. The
default is --skip-comments (discard comments), enable
with --comments.
-C, --compress Use compression in server/client protocol.
-#, --debug[=#] This is a non-debug version. Catch this and exit.
--debug-check Check memory and open file usage at exit.
-T, --debug-info Print some debug info at exit.
-D, --database=name Database to use.
--default-character-set=name
Set the default character set.
--delimiter=name Delimiter to be used.
-e, --execute=name Execute command and quit. (Disables --force and history
file.)
-E, --vertical Print the output of a query (rows) vertically.
-f, --force Continue even if we get an SQL error.
-G, --named-commands
Enable named commands. Named commands mean this program's
internal commands; see mysql> help . When enabled, the
named commands can be used from any line of the query,
otherwise only from the first line, before an enter.
Disable with --disable-named-commands. This option is
disabled by default.
-g, --no-named-commands
Named commands are disabled. Use \* form only, or use
named commands only in the beginning of a line ending
with a semicolon (;). Since version 10.9, the client now
starts with this option ENABLED by default. Disable with
'-G'. Long format commands still work from the first
line. WARNING: option deprecated; use
--disable-named-commands instead.
-i, --ignore-spaces Ignore space after function names.
--local-infile Enable/disable LOAD DATA LOCAL INFILE.
-b, --no-beep Turn off beep on error.
-h, --host=name Connect to host.
-H, --html Produce HTML output.
-X, --xml Produce XML output.
--line-numbers Write line numbers for errors.
-L, --skip-line-numbers
Don't write line number for errors.
-n, --unbuffered Flush buffer after each query.
--column-names Write column names in results.
-N, --skip-column-names
Don't write column names in results.
-O, --set-variable=name
Change the value of a variable. Please note that this
option is deprecated; you can set variables directly with
--variable-name=value.
--sigint-ignore Ignore SIGINT (CTRL-C).
-o, --one-database Ignore statements except those that occur while the
default database is the one named at the command line.
--pager[=name] Pager to use to display results. If you don't supply an
option, the default pager is taken from your ENV variable
PAGER. Valid pagers are less, more, cat [> filename],
etc. See interactive help (\h) also. This option does not
work in batch mode. Disable with --disable-pager. This
option is disabled by default.
--no-pager Disable pager and print to stdout. See interactive help
(\h) also. WARNING: option deprecated; use
--disable-pager instead.
-p, --password[=name]
Password to use when connecting to server. If password is
not given it's asked from the tty.
-P, --port=# Port number to use for connection or 0 for default to, in
order of preference, my.cnf, $MYSQL_TCP_PORT,
/etc/services, built-in default (3306).
--prompt=name Set the mysql prompt to this value.
--protocol=name The protocol to use for connection (tcp, socket, pipe,
memory).
-q, --quick Don't cache result, print it row by row. This may slow
down the server if the output is suspended. Doesn't use
history file.
-r, --raw Write fields without conversion. Used with --batch.
--reconnect Reconnect if the connection is lost. Disable with
--disable-reconnect. This option is enabled by default.
-s, --silent Be more silent. Print results with a tab as separator,
each row on new line.
-S, --socket=name The socket file to use for connection.
--ssl Enable SSL for connection (automatically enabled with
other flags).Disable with --skip-ssl.
--ssl-ca=name CA file in PEM format (check OpenSSL docs, implies
--ssl).
--ssl-capath=name CA directory (check OpenSSL docs, implies --ssl).
--ssl-cert=name X509 cert in PEM format (implies --ssl).
--ssl-cipher=name SSL cipher to use (implies --ssl).
--ssl-key=name X509 key in PEM format (implies --ssl).
--ssl-verify-server-cert
Verify server's "Common Name" in its cert against
hostname used when connecting. This option is disabled by
default.
-t, --table Output in table format.
--tee=name Append everything into outfile. See interactive help (\h)
also. Does not work in batch mode. Disable with
--disable-tee. This option is disabled by default.
--no-tee Disable outfile. See interactive help (\h) also. WARNING:
Option deprecated; use --disable-tee instead.
-u, --user=name User for login if not current user.
-U, --safe-updates Only allow UPDATE and DELETE that uses keys.
-U, --i-am-a-dummy Synonym for option --safe-updates, -U.
-v, --verbose Write more. (-v -v -v gives the table output format).
-V, --version Output version information and exit.
-w, --wait Wait and retry if connection is down.
--connect_timeout=# Number of seconds before connection timeout.
--max_allowed_packet=#
The maximum packet length to send to or receive from
server.
--net_buffer_length=#
The buffer size for TCP/IP and socket communication.
--select_limit=# Automatic limit for SELECT when using --safe-updates.
--max_join_size=# Automatic limit for rows in a join when using
--safe-updates.
--secure-auth Refuse client connecting to server if it uses old
(pre-4.1.1) protocol.
--server-arg=name Send embedded server this as a parameter.
--show-warnings Show warnings after every statement.
Default options are read from the following files in the given order:
/etc/mysql/my.cnf /etc/my.cnf ~/.my.cnf
The following groups are read: mysql client
The following options may be given as the first argument:
--print-defaults Print the program argument list and exit.
--no-defaults Don't read default options from any option file.
--defaults-file=# Only read default options from the given file #.
--defaults-extra-file=# Read this file after the global files are read.
Variables (--variable-name=value)
and boolean options {FALSE|TRUE} Value (after reading options)
auto-rehash TRUE
character-sets-dir (No default value)
column-type-info FALSE
comments FALSE
compress FALSE
debug-check FALSE
debug-info FALSE
database (No default value)
default-character-set latin1
delimiter ;
vertical FALSE
force FALSE
named-commands FALSE
ignore-spaces FALSE
local-infile FALSE
no-beep FALSE
host (No default value)
html FALSE
xml FALSE
line-numbers TRUE
unbuffered FALSE
column-names TRUE
sigint-ignore FALSE
port 0
prompt mysql>
quick FALSE
raw FALSE
reconnect FALSE
socket (No default value)
ssl FALSE
ssl-ca (No default value)
ssl-capath (No default value)
ssl-cert (No default value)
ssl-cipher (No default value)
ssl-key (No default value)
ssl-verify-server-cert FALSE
table FALSE
user root
safe-updates FALSE
i-am-a-dummy FALSE
connect_timeout 0
max_allowed_packet 16777216
net_buffer_length 16384
select_limit 1000
max_join_size 1000000
secure-auth FALSE
show-warnings FALSE
[nagios@MYUCBPNAGIAPP01 ~]$
Noted. You can close this thread.benjaminsmith wrote:Hi,
Sorry about that, try logging into mysql and then directly run the query.
