Utils.sh Error
dgilmore
Utils.sh Error
Post by dgilmore »
Dear Support Forum,
I'm trying to work with the check_rrdtraf script from the Nagios XI install. When I run the command from the command line, I'm receiving the following error.
'/utils.sh: line 9: syntax error near unexpected token `{
'/utils.sh: line 9: `print_revision() {
The script still executes but prints out an error of ": numeric argument requiredexit: 0"
This causes further issues with the program. Any help would be great, thanks in advance.
David
jomann
Development Lead
Re: Utils.sh Error
Post by jomann »
Are you running Nagios XI on Debian or Ubuntu? If so, can you try adjusting the first line of those files, the "/bin/sh" at the top of check_rrdtraf and utils.sh to be "/bin/bash" instead.
Re: Utils.sh Error
Can you show the command you are executing so we can try to reproduce it?
dgilmore
Re: Utils.sh Error
Post by dgilmore »
Thanks for all the replies. I replaced the utils.sh file with another one and the problem is fixed. Thanks!!
Re: Utils.sh Error
dgilmore wrote:Thanks for all the replies. I replaced the utils.sh file with another one and the problem is fixed. Thanks!!
great, glad to hear it is resolved!
Locking
