Hello team,
We are trying to monitor DNS Server in Nagios XI.
Need to monitor below services.
1. Monitor DNS Service availability.
2. Monitor DNS Service health status.
We have tried one one plugin but its not getting output.
So, can you please suggest solution for above required services to be monitor.
Monitoring DNS Server in Nagios XI
Re: Monitoring DNS Server in Nagios XI
I would recommend the DNS Query Wizard in Nagios XI
Hi scott,
Thanks for your reply.
I have configured some DNS server with DNS Query wizard.
We are facing error for some of the servers.
Error is like "Error: check_icmp failed"
I executed commands like "chmod u+s pluginfile"
But still we are facing issue. please help me.
Can you run the command from the command line as the nagios user, or using the Test command on the host in the CCM?
