ndo2db: 2.1.2
We have a number of Nagios servers which are overloaded and we are finding a bottleneck where the ndo2db processing the mqueue is not fast enough. This is causing the mqueue to fill up and cause problems, we are looking into all options including breaking up the monitors on the Nagios servers.
I wanted to find out if you have an alternative to ndo2db, so the remote database we have can get updated and we are no longer limited by the mqueue?
Server Specs:
CPU = 32 x Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz
Memory = 65 GB
Disk Mount = 322.1 GB
OS = CentOS Linux release 7.2.1511
Nagios Core 4.4.3
Last Modified: 2019-01-15
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 49004 services.
Checked 3273 hosts.
Checked 19016 host groups.
Checked 12167 service groups.
Checked 313 contacts.
Checked 19429 contact groups.
Checked 188 commands.
Checked 11 time periods.
Checked 0 host escalations.
Checked 3273 hosts
Checked 0 host dependencies
Checked 11 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
ipcs
------ Message Queues --------
key msqid owner perms used-bytes messages
0xf2000002 294912 nagios 600 262144000 256000
0x5d000002 2031617 nagios 600 262144000 256000
0xca000002 2621442 nagios 600 259445760 253365
0xd8000002 2654211 nagios 600 261363712 255238
0x09000002 2686980 nagios 600 261277696 255154
0x65000002 2883589 nagios 600 261379072 255253
0x49000002 2916358 nagios 600 0 0
------ Shared Memory Segments --------
key shmid owner perms bytes nattch status
0x011416ef 163840 root 600 1000 11
0x0001610e 196609 nagios 600 4096 225
0x0114338b 131074 root 600 1000 0
------ Semaphore Arrays --------
key semid owner perms nsems
0x00000000 589824 apache 600 1
0x00000000 622593 apache 600 1
0x00000000 229378 apache 600 1
0x00000000 655363 apache 600 1
0x00000000 688132 apache 600 1
0x00000000 720901 apache 600 1
0x00000000 851974 apache 600 1
0x00000000 884743 apache 600 1
0x00000000 819208 apache 600 1
0x00000000 917513 apache 600 1
0x00000000 950282 apache 600 1
0x00000000 983051 apache 600 1
