browser check
newmember
browser check
Post by newmember »
Client is changing browser deployment policy
I am being asked to validate if Nagios LS will be supported.
New Browsers:
Edge Chromium (Default)
Internet Explorer 11 (secondary)
Chrome (Optional Browser)
Going forward, all new apps should support HTML5
No Adobe Flash Plugin
No Oracle Java Plugin
No Internet Explorer
Are there any concerns with these policy changes?
Re: browser check
We don't use Java plugins from the interface, but we do run stuff on the backend with java, e.g. elasticsearch. If you are concerned primarily with the browsers, it's all good.
