NagiosXI dedicating unresponsive windows server
imadc
Post by imadc »
Hello Support
When Host Windows Server with NCPA Agent is undergoing 100% CPU usage
Is there a way for NagiosXI to alert us if a windows server is not responding since ping and telnet are working normally in this case?
or Is there a way to that NagiosXI know that no available resources for an NCPA agent to run on a windows server?
Insurity
Re: NagiosXI dedicating unresponsive windows server
Don't NCPA checks fail when there are "no available resources for an NCPA agent to run on a windows server"? Do you get notifications for the services in hard critical state? What is the status of the "CPU Usage" service?
imadc
Post by imadc »
So what I am getting with 100% CPU on the host
is all NCPA checks returning delayed feed back of - (Service check timed out after 60.01 seconds)
Is there another way to get notified earlier on such use-case? for example another check not through NCPA?
Below is the email that is sent which is not clear that the CPU is 100% and that is why the agent wasnt able to processes monitoring
***** Nagios XI Alert *****
Nagios has detected a problem with this service.
Notification Type: PROBLEM
Service: Srv H Grp - Disk Usage on C:/
Host:
Address:
State: CRITICAL
Info:
(Service check timed out after 61.01 seconds)
Date/Time: 2019-06-20 13:54:5
As for the PING it's status is OK
Insurity
Checking internals (various metrics on your server) would always require some type of agent. Even with "agentless" monitoring, e.g. using wmi or snmp, the system would need to have enough resources to perform the checks... NCPA does not require lots of CPU power to run, so I don't think using a different agent would solve the issue.
I would recommend that you find out what is causing the CPU spikes on the Windows server, and fix the issue, so that you could successfully monitor various metrics - disk usage, memory, etc.
Are you using active or passive NCPA checks? Can you post the ncpa_listener.log, ncpa_passive.log, win32service_ncpalistener.log, and win32service_ncpapassive.log on the forum. Please remove/obfuscate sensitive data.
imadc
Post by imadc »
I will give a try through WMI call since the agent didnt have resources to run in this use case
Sounds good. We will keep the thread for the time being. Thank you!
