Monitoring RAID
axvers
Monitoring RAID
Post by axvers »
Hi support,
We want to find a recommended plugin for monitoring RAID.
I checked this: https://www.nagios.com/solutions/raid-c ... onitoring/
But there is no straightforward solution about setting up the monitoring.
All I found is a lot of plugin in nagios exchange.
Let's say, we have HP DL3800 , IBM HS22, SUN x6250..., how should I do to monitor these RAID on Nagios XI?
benjaminsmith
Re: Monitoring RAID
Post by benjaminsmith »
Hi @axvers,
I would recommend searching the Nagios Exchange based upon which type of raid controller/hardware is utilized by the specific server. For example, it looks like the HP DL3800 uses HP Smart Arrary and may work with thsi plugin:
https://exchange.nagios.org/directory/P ... us/details
Once you have identified a suitable plugin, then you can upload into Nagios XI and test it on your device. For detailed insturctions, please see the following guide:
Managing Plugins in Nagios XI
Let us know if you have any questions.
