Acknowledgment of Traps
jatindeepsharma
Post by jatindeepsharma »
Hi Team,
When i am acknowledging a trap, it is getting acknowledged but it is not getting disappeared from interface. so it creates confusion & i am opening same trap again.
can you please help how can i get rid of same?
Re: Acknowledgment of Traps
It depends on where you are looking in the UI, for example if you go to
Home -> Open Service Problems
This will only show services that have not been acknowledged or are not in downtime
Additionally, acknowledged items should have an icon that looks like a wrench next to the service description in the table view
jatindeepsharma
Thank you so much scottwilkerson, but is there any way like if i have acknowledged critical trap & it will get disappear?
cdienger
Post by cdienger »
Where would you like it to disappear from exactly? Is it enough that it goes back into an OK state? If so, you could submit another passive check result. Do this on the service's status detail screen > Advanced > Commands > Submit passive check result.
