Nagios Core - LogFile Monitoring in Unix server
pbachu2
Post by pbachu2 »
Hi All,
We are using Nagios Core 4.0.8 and we got a request to monitor for "Error" word in the log file on Unix server.
We tried configuring this service using check_log plugin .
Check command in Service definition on host.cfg is as below:
check_command check_log_dc1uat163_oldone!-F /apps/wildfly-11.0.0/standalone/log/server.log.2019-06-20 -O /apps/wildfly-11.0.0/standalone/log/server.log -q "ERROR"
commands.cfg is below:
command_name check_log_dc1uat163_oldone
command_line $USER2$/check_log $ARG1$ $ARG2$ $ARG3$
However it is giving error as below:
Log check error: Log file /apps/wildfly-11.0.0/standalone/log/server.log.2019-06-20 does not exist!
Can someone pls suggest how to configure for this kind of monitoring.
Priyanka
[email protected]
benjaminsmith
Re: Nagios Core - LogFile Monitoring in Unix server
Post by benjaminsmith »
Hi Priyanka,
Are your sure you have the correct file path as it cannot find it. Does the Nagios user on the server have permissions to access the log file?
su nagios
ls -l /apps/wildfly-11.0.0/standalone/log/server.log.2019-06-20
Let me know. Thanks.
pbachu2
Post by pbachu2 »
Hi Smith,
Thanks for your prompt response.
Yes we are able to perform steps you provided.
[root@dc1uat163 ~]# su nagios
[nagios@dc1uat163 root]$ ls -l /apps/wildfly-11.0.0/standalone/log/server.log.2019-06-20
-rw-r--r-- 1 root root 30182209 Jun 20 23:59 /apps/wildfly-11.0.0/standalone/log/server.log.2019-06-20
Please suggest how to proceed further.
benjaminsmith
If the file is there, then you'll need to change the permissions to allow access by the nagios user account. For the check_log plugin, do this for both files in your check command.
For example,
chgrp nagios /apps/wildfly-11.0.0/standalone/log/server.log.2019-06-20
chmod 770 /apps/wildfly-11.0.0/standalone/log/server.log.2019-06-20
pbachu2
Post by pbachu2 »
Hi Smith,
Yes we did tried changing permissions for the file as per your suggestion.But we are getting same error.
Could you please help us know if any other way to configure similar kind of monitoring.
Please suggest.
Regards,
Priyanka
[email protected]
benjaminsmith
Log into /usr/local/nagios/libexec on the Nagios server and running the following command:
./check_log -F /apps/wildfly-11.0.0/standalone/log/server.log.2019-06-20 -O /apps/wildfly-11.0.0/standalone/log/server.log -q "error"
and provide a screenshot or post the output. If the file exists and Nagios has access to the file it should work.
pbachu2
Post by pbachu2 »
Hi Smith,
I am getting below error.
./check_log: line 76: ./utils.sh: No such file or directory
Also attaching check_log plugin which we are using. PFA and suggest.
Thanks & Regards,
Priyanka Bachu
check_log.txt
(6.13 KiB) Downloaded 210 times
ssax
Dreams In Code
Post by ssax »
It needs to be run from within the directory that contains utils.sh, please do it this way:
su - nagios
cd /usr/local/nagios/libexec/
pbachu2
Post by pbachu2 »
Hi ,
Please check the output below and please suggest.
I have run this command on the remote server.
[root@dc1uat163 ~]# su - nagios
[nagios@dc1uat163 ~]$ cd /usr/local/nagios/libexec/
[nagios@dc1uat163 libexec]$ ./check_log -F /apps/wildfly-11.0.0/standalone/log/server.log.2019-06-20 -O /apps/wildfly-11.0.0/standalone/log/server.log -q "error"
./check_log: line 209: /apps/wildfly-11.0.0/standalone/log/server.log: Permission denied
(59) < at bravura.sonata.application.useragent.UserAgent.errorDialog(UserAgent.java:105)[nagios@dc1uat163 libexec]$
Regards,
Priyanka
ssax
Dreams In Code
Post by ssax »
It tells you the issue:
The nagios user doesn't have access to write to this file:
What are the permissions on there?
