hello,
i am working on a Nagios XI installation for a campus LAN. is it possible to get only the status map page WITHOUT any login? i want to share the map as a public page in an intranet site.
thanks in advance!
Getting status map WITHOUT login
Re: Getting status map WITHOUT login
There may be other ways of doing that, but here's one way I can think of.
1. Go to: Admin > System Config > System Settings > Backward Compatibility > Allow Insecure Logins = checked > Update Settings
2. Create an admin user (or user nagiosadmin). Click on the username in the upper-right corner, and click on "Generate new insecure ticket" if you don't have one already created. Copy the <insecure login ticket> - you will use it in the next step.
3. Use a URL as the one below:
where you substitute <username> and <insecure login ticket> with actual username and ticket, e.g.
Note: Users need to be authorized to see the data on the map, so you will have to use an admin user in order to make sure all data will be visible.
http://ip/nagiosxi/includes/components/statusmap/index.php?username=<username>&ticket=<insecure login ticket>Code: Select all
http://192.168.0.100/nagiosxi/includes/components/statusmap/index.php?username=john&ticket=h6LWd4VkrQQjR0foL2D05SuTWRBuvT76Y8jbrevVkFurVMSX4LX8EL0QDRkoKKNZBe sure to check out our Knowledgebase for helpful articles and solutions!
