SOAP Script monitoring
Srinija544
Post by Srinija544 »
Hi All,
We are using Nagios Core and we have a new request to monitor SOAP Script. Please find the below script:
--soap '<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:sal="http://www.sonatacentral.com/service/v3 ... leschannel" xmlns:ser="http://www.sonatacentral.com/service/v30/Service" xmlns:cal="http://www.sonatacentral.com/service/v30/CallerDetails" xmlns:iden="http://www.sonatacentral.com/service/v3 ... tifierType" xmlns:dat="http://www.sonatacentral.com/service/v3 ... v:Envelope>'
We have placed this script in Nagios server using this command:
check_command check_soap!--action "GetResponse" --url "http://dc1uat163.twruat.ext/sonata/serv ... nelService" --grep '(?<=40000001>)[0-9]+(?=</)' --soap '<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:sal="http://www.sonatacentral.com/service/v3 ... leschannel" xmlns:ser="http://www.sonatacentral.com/service/v30/Service" xmlns:cal="http://www.sonatacentral.com/service/v30/CallerDetails" xmlns:iden="http://www.sonatacentral.com/service/v3 ... tifierType" xmlns:dat="http://www.sonatacentral.com/service/v3 ... v:Envelope>'
However we are getting an error message as below:
SOAP UNKNOWN: Failed to extract value from response
Please someone help me on this request.
Regards,
Srinija.
cdienger
Re: SOAP Script monitoring
Post by cdienger »
I'm not familiar with that plugin. Can you provide a link to download it or attach it to the ticket? Are you able to run it directly from the command line?
Srinija544
Hi cdienger,
Thank you for your response.
Please find the attached script of check_soap plugin which we are using for our alert. We are using this script in our Nagios server.
We have command to this in our commands.cfg file:
command_name check_soap
command_line $USER1$/monitoring-plugins/check_soap.sh $ARG1$
Could you please check and help me on this?
check_soap.txt
(3.65 KiB) Downloaded 956 times
cdienger
Post by cdienger »
Run the command like this to get debug output:
bash -x /usr/local/nagios/libexec/check_soap.sh --action "GetResponse" --url "http://www.gosomethingsomething.com" --grep '(?<=40000001>)[0-9]+(?=</)' --soap '<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:sal="http://www.sonatacentral.com/service/v30/common/saleschannel" xmlns:ser="http://www.sonatacentral.com/service/v30/Service" xmlns:cal="http://www.sonatacentral.com/service/v30/CallerDetails" xmlns:iden="http://www.sonatacentral.com/service/v30/globaltypes/IdentifierType" xmlns:dat="http://www.sonatacentral.com/service/v30/globaltypes/common/data/DataGroupType"><soapenv:Header/><soapenv:Body><sal:getLocationRequest><ser:CallerDetails><cal:username>demo</cal:username><cal:country>AU</cal:country><cal:language>en</cal:language><cal:databaseIdentifier>SONUAT</cal:databaseIdentifier></ser:CallerDetails><sal:LocationIdentifier><iden:id>40000001</iden:id></sal:LocationIdentifier></sal:getLocationRequest></soapenv:Body></soapenv:Envelope>'
