Hello.
new 18.04 server with 4.x nagios running.
my configs (switch/server/etc) have commands in them like - check_snmp or check_hpjd to check different process. I'm getting failures whenever i check these services and it seems like those - and probably other 'check_insert-name-here' commands are in my /libexec directory. As this was/is a default config - and i rant the process for getting nagios-plugins-release-2.2.1 including the compile/build/make/etc I'd thought I have all the 'plugins' and commands that i need. Apparantly not.
Where are those plugins - or all, even if i dont need them now - so that i can continue on. The devices answer back with ping - but none of the otehr info is being processed or retrieved.
i've installed ncpa and can open/view on the host server w/o issues.
thanks -
missing plugins ?
Re: missing plugins ?
How did you install Nagios Core and nagios plugins? Did you following the guides below?
https://support.nagios.com/kb/article/n ... tml#Ubuntu
https://support.nagios.com/kb/article/n ... tml#Ubuntu]
Can you list the plugins that you currently have in the libexec directory?
ls -la /usr/local/nagios/libexecBe sure to check out our Knowledgebase for helpful articles and solutions!
