nrpe installation error(configure: error)
sandeep027
Post by sandeep027 »
Hi All,
When i am trying to install nrep, i am getting below error..Please help on this.
Error : checking for SSL headers... configure: error: Cannot find ssl headers
post that i tired the below command , but still getting same error.
./configure --enable-ssl
post that i tried to install this yum command - yum install openssl-devel -y but getting below errors
Error downloading packages:
libsepol-devel-2.5-8.1.el7.x86_64: [Errno 256] No more mirrors to try.
libselinux-devel-2.5-12.el7.x86_64: [Errno 256] No more mirrors to try.
krb5-devel-1.15.1-18.el7.x86_64: [Errno 256] No more mirrors to try.
1:openssl-devel-1.0.2k-12.el7.x86_64: [Errno 256] No more mirrors to try.
zlib-devel-1.2.7-17.el7.x86_64: [Errno 256] No more mirrors to try.
libverto-devel-0.2.5-4.el7.x86_64: [Errno 256] No more mirrors to try.
keyutils-libs-devel-1.5.8-3.el7.x86_64: [Errno 256] No more mirrors to try.
libcom_err-devel-1.42.9-11.el7.x86_64: [Errno 256] No more mirrors to try.
libkadm5-1.15.1-18.el7.x86_64: [Errno 256] No more mirrors to try.
pcre-devel-8.32-17.el7.x86_64: [Errno 256] No more mirrors to try
Can any one please help on this.
benjaminsmith
Re: nrpe installation error(configure: error)
Post by benjaminsmith »
What operating system are you installing NRPE on and what instructions are you using?
The easiest way to install NRPE is by using the install script as it will set everything up for you.
See: NRPE - How to install NRPE
Alternatively, you can install NRPE directly from source: NRPE - How To Install NRPE v3 From Source
Regarding the errors, does you server have access to the internet? What is the output to:
yum repolist
sandeep027
Thanks for responding.. please find the below output of yum repolist
-bash-4.2# yum repolist
Loaded plugins: langpacks, product-id, search-disabled-repos, subscription-manager
This system is not registered with an entitlement server. You can use subscription-manager to register.
file:///mnt/repodata/repomd.xml: [Errno 14] curl#37 - "Couldn't open file /mnt/repodata/repomd.xml"
Trying other mirror.
repo id repo name status
InstallMedia Red Hat Enterprise Linux 7.5 5,099
!LocalRepo Local Repository 5,099
epel/x86_64 Extra Packages for Enterprise Linux 7 - x86_64 13,242
repolist: 23,440
-bash-4.2#
I have followed the link the below link to install NRPE , but getting the same error.
https://support.nagios.com/kb/article.php?id=515#RHEL
As per link first i tried to install the below one
yum install -y gcc glibc glibc-common openssl openssl-devel perl wget
but getting below error. please check the errror as below
-bash-4.2# yum install -y gcc glibc glibc-common openssl openssl-devel perl wget
Package gcc-4.8.5-28.el7.x86_64 already installed and latest version
Package glibc-2.17-222.el7.x86_64 already installed and latest version
Package glibc-common-2.17-222.el7.x86_64 already installed and latest version
Package 1:openssl-1.0.2k-12.el7.x86_64 already installed and latest version
Package 4:perl-5.16.3-292.el7.x86_64 already installed and latest version
Package wget-1.14-15.el7_4.1.x86_64 already installed and latest version
Resolving Dependencies
--> Running transaction check
---> Package openssl-devel.x86_64 1:1.0.2k-12.el7 will be installed
--> Processing Dependency: krb5-devel(x86-64) for package: 1:openssl-devel-1.0.2k-12.el7.x86_64
--> Processing Dependency: zlib-devel(x86-64) for package: 1:openssl-devel-1.0.2k-12.el7.x86_64
---> Package krb5-devel.x86_64 0:1.15.1-18.el7 will be installed
--> Processing Dependency: libkadm5(x86-64) = 1.15.1-18.el7 for package: krb5-devel-1.15.1-18.el7.x86_64
--> Processing Dependency: keyutils-libs-devel for package: krb5-devel-1.15.1-18.el7.x86_64
--> Processing Dependency: libcom_err-devel for package: krb5-devel-1.15.1-18.el7.x86_64
--> Processing Dependency: libselinux-devel for package: krb5-devel-1.15.1-18.el7.x86_64
--> Processing Dependency: libverto-devel for package: krb5-devel-1.15.1-18.el7.x86_64
---> Package zlib-devel.x86_64 0:1.2.7-17.el7 will be installed
---> Package keyutils-libs-devel.x86_64 0:1.5.8-3.el7 will be installed
---> Package libcom_err-devel.x86_64 0:1.42.9-11.el7 will be installed
---> Package libkadm5.x86_64 0:1.15.1-18.el7 will be installed
---> Package libselinux-devel.x86_64 0:2.5-12.el7 will be installed
--> Processing Dependency: libsepol-devel(x86-64) >= 2.5-6 for package: libselinux-devel-2.5-12.el7.x86_64
--> Processing Dependency: pkgconfig(libpcre) for package: libselinux-devel-2.5-12.el7.x86_64
--> Processing Dependency: pkgconfig(libsepol) for package: libselinux-devel-2.5-12.el7.x86_64
---> Package libverto-devel.x86_64 0:0.2.5-4.el7 will be installed
---> Package libsepol-devel.x86_64 0:2.5-8.1.el7 will be installed
---> Package pcre-devel.x86_64 0:8.32-17.el7 will be installed
Dependencies Resolved
Package Arch Version Repository Size
Installing:
openssl-devel x86_64 1:1.0.2k-12.el7 InstallMedia 1.5 M
Installing for dependencies:
keyutils-libs-devel x86_64 1.5.8-3.el7 InstallMedia 37 k
krb5-devel x86_64 1.15.1-18.el7 InstallMedia 269 k
libcom_err-devel x86_64 1.42.9-11.el7 InstallMedia 31 k
libkadm5 x86_64 1.15.1-18.el7 InstallMedia 175 k
libselinux-devel x86_64 2.5-12.el7 InstallMedia 186 k
libsepol-devel x86_64 2.5-8.1.el7 InstallMedia 77 k
libverto-devel x86_64 0.2.5-4.el7 InstallMedia 12 k
pcre-devel x86_64 8.32-17.el7 InstallMedia 480 k
zlib-devel x86_64 1.2.7-17.el7 InstallMedia 50 k
Transaction Summary
Install 1 Package (+9 Dependent packages)
Total download size: 2.8 M
Installed size: 6.0 M
Downloading packages:
pcre-devel-8.32-17.el7.x86_64: [Errno 256] No more mirrors to try.
-bash-4.2#
Post by mcapra »
It looks like all you have for configured repositories are the local installation media, EPEL, and a custom repomd.xml file that the system is unable to read from some custom mount. Is it possible that this system is trying to reference some internal repositories for your organization that were not correctly configured? Most RHEL/CentOS systems install with Base and Extras repositories enabled by default, though if this is a custom installation/image or offline instance of RHEL/CentOS those may have been disabled.
sandeep027
Actually Last week OS was upgraded on this server, and post that i am facing this issues. May be they used image or cloned while upgrading OS.
Now how to resolve this Nagios issue.
First thing to do it to clear all of the yum settings so it can refresh the data for the repo's it needs to get the packages.
Run this as root
yum clean all
Then run this to see if the package can be downloaded.
yum install -y openssl-devel
Also, it looks like the server is not registered with Redhat and sometimes that causes yum issues.
You may have to register the server to allow yum to download and install packages.
sandeep027
Thank you so much bro.. i am able to install openssl packages with the help of Linux team. Post that i have configured the Nagios monitoring and now all the monitoring services are up and running fine. Thanks for your help and Thanks to all.
Really appreciate !
sandeep027 wrote:Thank you so much bro.. i am able to install openssl packages with the help of Linux team. Post that i have configured the Nagios monitoring and now all the monitoring services are up and running fine. Thanks for your help and Thanks to all.
Really appreciate !
Glad to hear it is working!
Locking thread
