Hey everyone,
I can't manage via web GUI
admin->System Status->Subsystems
Elasticsearch Database
Logstash Collector
I only see a yellow triangle to the left of
[yellow triangle] Elasticsearch Database
[yellow triangle] Logstash Collector
if I move over the mouse I get :
"Could not authenticate. Invalid token given"
before I could do the following actions
(green ball) Elasticsearch Database [Restart]
(green ball) Logstash Collector [Restart] [Stop]
the screenshot of the problem is attached.
At the beginning it was working
Thanks in advance
Nick
Problem "Could not authenticate. Invalid token given"
nagioscarnovale
Re: Problem "Could not authenticate. Invalid token given"
The token that it is referring to is the user's API key. Try resetting it and let us know your results.
nagioscarnovale
These days we have installed the version directly
"Nagios Log Server 2.0.8" and the problem is solved
Thanks so much for the support
Glad to hear!
