Hi Experts,
Seeking for your help as we are experiencing error in our Metrics Overview. One of our Plug-ins is not accurate in terms of Color coding state.
One of our servers are in DISK USAGE Critical State but in Metrics Overview the Critical State color is GREEN. Please see attached file for your reference.
Troubleshooting done:
1. Reboot the Nagios XI server. ~Not resolving.
2. Re-configure Host & Services. ~Not resolving.
3. Checked the Server's Performance however its all in normal utilization.
Note : Yesterday, it was working fine but earlier today, it is now experiencing this error.
Metric Overview Problem - Color Coding Error
Re: Metric Overview Problem - Color Coding Error
Hi Experts,
Hoping for your ASAP feedback.
Are these checks that are not color-coded properly NCPA checks? If so, it's been fixed in 5.6.4 and should be out shortly.
===========================================jomann wrote:Hello,
Hi Mr. Jomann,
Thanks for your feedback on this.
Sorry, did you mean during installation of NCPA agent app we haven't properly configured to check the color-coding for each state? Will, if you could try on your end to install the NCPA agent, there's no option of it as the option only is Input the Auth Token, NRDP IP.. etc..
Also, what version exactly you are using. Because for now I think the latest update is 5.6.3. do you know already when is the launching 5.6.4 update?
Thank you.
Best regards
5.6.4 of Nagios XI should be released in the next few days with the fix included.rubragat wrote:Also, what version exactly you are using. Because for now I think the latest update is 5.6.3. do you know already when is the launching 5.6.4 update?
Hi Mr. Scottwilkerson,
Please kindly let us know then once the update is already available online so we can implement it right away in our end and see if our experienced error will fix.
Thank you.
Best regards,
Marco
Thank you.
Best regards,
Marco
This will likely be early next week
scottwilkerson wrote:This will likely be early next week
Hi Scott,
Metrics COLOR are now aligned with the Status STATE after the update to 5.6.4.
Thank you.
Great. Was just coming back to tell you 5.6.4 was released and saw this.rubragat wrote:scottwilkerson wrote:This will likely be early next week
Hi Scott,
Thank you.
Locking thread
