Force passive check Nsclient++ Service starting
rambertnala
Post by rambertnala »
Hi from Spain.
I would like to know, if there is a chance to make Nsclient++ sent all checks when service Nsclient++ on windows host is started and not have to wait interval time setup on nsclient.in
[/settings/scheduler/schedules]
Command1
Command2
Command8
[/settings/scheduler/schedules/default]
interval = 30
channel = NRDP
[/settings/scheduler]
threads = 10
When process nscp.exe is up via windows service I have to wait 30 minutes to receive information, and i would like to receive it about 3-5 minutes after nsclient++ windows service is started
My nsclient++ version is 0.5.1.46
Thanks for all
Re: Force passive check Nsclient++ Service starting
The simplest thing to do is to change the interval to 5 minutes so it will run withing the time you want.
Reference for the scheduler settings in the nsclient.ini file.
https://docs.nsclient.org/reference/generic/Scheduler/
I did not see a way to have the schedule run the commands at startup so you may want to post this question on the NSClient++ forums to see if you can find the answer there.
https://forums.nsclient.org/
rambertnala
Problem is i do not want to change it.
I only want to force to send data when service is started and after that, wait for my normal period.
I could not find an option or settings to do that in the NSClient++ documentation.
What I did find is an option called randomness that is used to randomize the scheduler but I did not find what to set that option to except it defaults to 0.
rambertnala
So there is no any chance????
Thanks a lot
rambertnala
I hope anybody could help me or get an idea!!!
Regards
You would have to contact the author of the agent to see if the functionality you want is there.
