Hi Team,
I am finding that when we click on report tab in nagiosxi, Why last 24 hours availability report is fet
ching. Due to this server get using load because its fetching all host data while its fetching the data its taking more usage on nagios server.
If we have 1000 server its fetching 1000 servers host data, Can't we disable this automatic fetching report? Hope this idea will help to avoid the resource usage.
When click on report tab availability report is fetching
grayloglearn
Re: When click on report tab availability report is fetching
This should be possible if you're on a recent version of XI - under Admin > Performance Settings there is an "Auto-Running" tab where you can disable automatic running of reports.
grayloglearn
Thanks for the reply. We disabled it now load decreased . you can close the ticket.
great!grayloglearn wrote:Thanks for the reply. We disabled it now load decreased . you can close the ticket.
Locking thread
