Fusion 2014R1.0 with XI 5.5.11
This support forum board is for questions relating to Nagios Fusion.
elade
Post by elade »
I tried to connect my remote XI (5.5.11) to the fusion (version 2014R1.0).
I have local alerts in the xi but not fusion.
The API is is working from the fusion machine so there is no problem with communication.
Dose the fusion support new version of XI?
If not what are my options?
Re: Fusion 2014R1.0 with XI 5.5.11
You will have to upgrade the Fusion server as the newer version of XI is not compatible with the older version of Fusion.
To do that, follow this document to upgrade your existing Nagios Fusion installation with the latest updates and patches.
https://assets.nagios.com/downloads/nag ... ctions.pdf
