One of our client has a Vmware environment with approx 30 esxi cluster & 1 Vcenter server. all the user are AD authenticated, we have created a global user with read-only permission for Vmware and it inherit to Vcenter & all the ESXi.
Issue is we are able to monitor vcenter successfully also pull all the guests & monitor is successfully.
But when we try to add ESXI individually it gives the error
"check_vmware_api.pl CRITICAL - Error: Permission to perform this operation was denied."
We can confirm that credentials are correct as they are working with vCenter, also to reconfirm when we tried using user with administrator right we where successful getting details from esxi.
so can you confirm on the permission required by user for esxi other than read-only
