I think I found a bug in XI 5.6.3, in the CCM.
Steps to reproduce:
- Add a new service or edit an old one
- Press the "Manage Host Groups" button and add the "*" meta hostgroup to the service, save the service
- Press the "view config" button for the service, or try to apply the new configuration
- In both cases, an error 500 appears and the corresponding config file is empty, even if there are other services with that config name.
Thanks, Gonzalo
CCM error when adding * hostgroup to service
Re: CCM error when adding * hostgroup to service
I was able to recreate the issue and created an internal bug report (task_id=14334). The problem will be fixed in the next release of Nagios XI (5.6.4). Thank you for reporting the issue!
