Hi. I'm trying to upgrade from version 5.5.11 to 5.6.3, but the upgrade script is failing with the following error after the backup:
"No package php54-imap available."
There seems to be an issue with the line 211 of the upgrade script, because the correct package name should be php54-php-imap instead of php54-imap (at least in Centos 6).
Thanks, Gonzalo
Upgrade script fails
Re: Upgrade script fails
What is the output of the following command?
yum list installed php*common* | grep php | awk -F "-" {'print $1'} | tail -1Be sure to check out our Knowledgebase for helpful articles and solutions!
The output of that command was "php54"... The issue is that the package "php54-imap" does not seem to exist in Centos 6 (or maybe my repositories are misconfigured)
To complete the upgrade, I just replaced the ending of that line of the script with tail -1`-php-imap -y
It seems like you have been able to resolve the issue. Is it OK if we close the topic?To complete the upgrade, I just replaced the ending of that line of the script with tail -1`-php-imap -y
Sure, you can close it. Thanks
