Kukkurloom
Posts: 11 Joined: Thu Jul 04, 2019 2:00 am
Post
by Kukkurloom » Thu Jul 04, 2019 4:36 am
Hello boys and girls!
I am quite a beginner in Nagios monitoring system and I was adding check_hpjd plugin to monitor different services of my printer (toner etc), but unfortunately it does not work. It gives me:
Timeout from host: [IP] . When I ping this IP address it responds with any issues and now im stuck with that issue, could you please help me to get on a right path where can I fix this issue.
Thank you all,
Have a nice holiday aswell!
benjaminsmith
Posts: 5324 Joined: Wed Aug 22, 2018 4:39 pm
Post
by benjaminsmith » Mon Jul 08, 2019 4:39 pm
Thank you!
What model printer are you monitoring? What happens you run your check command directly from the terminal in
/usr/local/nagios/libexec ?
For example,
./check_hpjd -H <ip address> -C public -p 161
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
Be sure to check out our
Knowledgebase for helpful articles and solutions!
Kukkurloom
Post
by Kukkurloom » Tue Jul 09, 2019 2:18 am
Hello Benjamin!
Thank you for your reply, I ran the command in terminal and got the same timeout error:
[root@nagios libexec]# ./check_hpjd -H [IP] -C public -p 161
: Timeout from host [IP]
In regards with the printer type, we have different printers in the office, I ran that command pinging printer which model is:
HP Color LaserJet CP5225n also tried the same with printer
HP LaserJet Pro MFP M127fn
Edit:
I did a quick Zenmap scan to check whether there may be issues with open/closed ports and I can see that jetdirect (which is being used by that plugin) is on port 9100, should I change the port from 161 to 9100?
Edit #2:
Ran the same command as mentioned above with port 9100
[root@nagios libexec]# ./check_hpjd -H [IP] -C public -p 9100
Still a timeout...
Thank you for your help,
All the best,
Kukkurloom!
benjaminsmith
Post
by benjaminsmith » Wed Jul 10, 2019 12:35 pm
Hell Kukkurloom,
Did you enable SNMP on the printer? Try running an SNMPWalk from the Nagios server to see if you can reach the printer.
snmpwalk -v 2c -c communitystring <printer ip address>
Privacy Policy .
Kukkurloom
Post
by Kukkurloom » Thu Jul 18, 2019 5:44 am
Hello benjaminsmith!
I apologize for my late reply, but I ran the desired command:
[root@nagios ~]# snmpwalk -v 2c -c communitystring [IP]
Timeout: No Response from [IP]
Edit #1:
I had a small progress, but now it gives me an error:
snmpget: Failure in sendto (Invalid argument) : Timeout from host [IP]
If I run service service snmpd status command it say its active and running.
Best wishes,
Kukkurloom.
benjaminsmith
Post
by benjaminsmith » Fri Jul 19, 2019 12:43 pm
Hi
@kukkurloom ,
Are you able to ping the device and get a response?
If that works, then try running the snmpwalk command using version 1 as the printer may not support v2.
snmpwalk -v1 -c communitystring <ip addresss>
Let me know if you're able to get a response.
Privacy Policy .
Kukkurloom
Post
by Kukkurloom » Wed Jul 24, 2019 2:19 am
Hello benjaminsmith,
Thank you very much for your help!
Here are the results of the usual pinging session:
Pinging [IP] with 32 bytes of data:
Reply from [IP]: bytes=32 time<1ms TTL=255
Ping statistics for [IP]:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Edit #1: Ran the same ping command in Nagios terminal aswell:
[root@nagios libexec]# ping [IP]
PING [IP] ([IP]) 56(84) bytes of data.
64 bytes from [IP]: icmp_seq=1 ttl=254 time=6.54 ms
64 bytes from [IP]: icmp_seq=2 ttl=254 time=6.37 ms
64 bytes from [IP]: icmp_seq=3 ttl=254 time=12.8 ms
64 bytes from [IP]: icmp_seq=4 ttl=254 time=6.39 ms
64 bytes from [IP]: icmp_seq=5 ttl=254 time=12.9 ms
64 bytes from [IP]: icmp_seq=6 ttl=254 time=6.26 ms
64 bytes from [IP]: icmp_seq=7 ttl=254 time=12.9 ms
64 bytes from [IP]: icmp_seq=8 ttl=254 time=6.26 ms
64 bytes from [IP]: icmp_seq=9 ttl=254 time=6.25 ms
64 bytes from [IP]: icmp_seq=10 ttl=254 time=6.17 ms
64 bytes from [IP]: icmp_seq=11 ttl=254 time=6.28 ms
64 bytes from [IP]: icmp_seq=12 ttl=254 time=12.9 ms
--- [IP] ping statistics ---
12 packets transmitted, 12 received, 0% packet loss, time 11015ms
rtt min/avg/max/mdev = 6.174/8.523/12.984/3.122 ms
And here are the results of the second snmpwalk:
[root@nagios ~]# snmpwalk -v1 -c communitystring [IP]
Edit #2: Also did ran the ./check_hpjd plugin directly from the directory:
[root@nagios libexec]# ./check_hpjd [IP] -C public -p 161
Edit #3: Wandered around a little bit and checked the status of SNMPD and it gave me error like this, maybe this is the reason it wont work?:
Jul 24 10:55:02 nagios snmpd[7412]: Warning: no access control information configured.
(Config search path: /etc/snmp:/usr/share/snmp:/usr/lib64/snmp)
It's unlikely this agent can serve any useful purpose in this state....
Edit #4: Checked from the printer administration page perhaps something maybe SNMP is disabled or smth. but:
Edit #5: Sorry for so many edits, but I had some progress, when I run snmpwalk now then I get ALOT of text giving me ALOT of information about the printer, but in the web interface it still says the same error: snmpget: Failure in sendto (Invalid argument) : Timeout from host [IP]
Best wishes,
Kukkurloom.
benjaminsmith
Post
by benjaminsmith » Wed Jul 24, 2019 3:47 pm
That sounds like the snmpwalk is working. Can you post the output of snmpwalk?
From the plugin source code, here are the OIDs being used by check_hpjd.
#define HPJD_LINE_STATUS ".1.3.6.1.4.1.11.2.3.9.1.1.2.1"
#define HPJD_PAPER_STATUS ".1.3.6.1.4.1.11.2.3.9.1.1.2.2"
#define HPJD_INTERVENTION_REQUIRED ".1.3.6.1.4.1.11.2.3.9.1.1.2.3"
#define HPJD_GD_PERIPHERAL_ERROR ".1.3.6.1.4.1.11.2.3.9.1.1.2.6"
#define HPJD_GD_PAPER_OUT ".1.3.6.1.4.1.11.2.3.9.1.1.2.8"
#define HPJD_GD_PAPER_JAM ".1.3.6.1.4.1.11.2.3.9.1.1.2.9"
#define HPJD_GD_TONER_LOW ".1.3.6.1.4.1.11.2.3.9.1.1.2.10"
#define HPJD_GD_PAGE_PUNT ".1.3.6.1.4.1.11.2.3.9.1.1.2.11"
#define HPJD_GD_MEMORY_OUT ".1.3.6.1.4.1.11.2.3.9.1.1.2.12"
#define HPJD_GD_DOOR_OPEN ".1.3.6.1.4.1.11.2.3.9.1.1.2.17"
#define HPJD_GD_PAPER_OUTPUT ".1.3.6.1.4.1.11.2.3.9.1.1.2.19"
#define HPJD_GD_STATUS_DISPLAY ".1.3.6.1.4.1.11.2.3.9.1.1.3"
From the terminal on Nagios, run the following snmpwalk command on the status OID and post the output.
snmpwalk <ip-address> -c public -v 1 -OQa .1.3.6.1.4.1.11.2.3.9.1.1.3
Let us know if you're able to connect to the printer.
Privacy Policy .
Kukkurloom
Post
by Kukkurloom » Thu Jul 25, 2019 2:15 am
Hello benjamin!
Thank you for your reply!
Ran the command you asked me to and the result is:
[root@nagios ~]# snmpwalk [IP] -c public -v 1 -OQa .1.3.6.1.4.1.11.2.3.9.1.1.3
SNMPv2-SMI::enterprises.11.2.3.9.1.1.3.0 = "PowerSave on."
The result of a usual snmpwalk with the same IP aadress:
snmpwalk -v1 -c public [IP]
SNMPv2-MIB::sysDescr.0 = STRING: HP ETHERNET MULTI-ENVIRONMENT,SN:[SN],FN:[FN],SVCID:[ID],PID:HP Color LaserJet CP5225n
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.11.2.3.9.1
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (86929065) 10 days, 1:28:10.65
SNMPv2-MIB::sysContact.0 = STRING: IT
SNMPv2-MIB::sysName.0 = STRING: 3rdFloorHP
SNMPv2-MIB::sysLocation.0 = STRING: HP Color LaserJet CP5225n
SNMPv2-MIB::sysServices.0 = INTEGER: 72
SNMPv2-MIB::sysORLastChange.0 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORID.1 = OID: SNMPv2-MIB::snmpMIB
SNMPv2-MIB::sysORID.2 = OID: SNMP-FRAMEWORK-MIB::snmpFrameworkMIBCompliance
SNMPv2-MIB::sysORID.3 = OID: SNMP-MPD-MIB::snmpMPDCompliance
SNMPv2-MIB::sysORID.4 = OID: SNMP-USER-BASED-SM-MIB::usmMIBCompliance
SNMPv2-MIB::sysORID.5 = OID: SNMP-VIEW-BASED-ACM-MIB::vacmMIBCompliance
SNMPv2-MIB::sysORDescr.1 = STRING: The MIB Module from SNMPv2 entities
SNMPv2-MIB::sysORDescr.2 = STRING: SNMP Management Architecture MIB
SNMPv2-MIB::sysORDescr.3 = STRING: Message Processing and Dispatching MIB
SNMPv2-MIB::sysORDescr.4 = STRING: USM User MIB
SNMPv2-MIB::sysORDescr.5 = STRING: VACM MIB
SNMPv2-MIB::sysORUpTime.1 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.2 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.3 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.4 = Timeticks: (0) 0:00:00.00
SNMPv2-MIB::sysORUpTime.5 = Timeticks: (0) 0:00:00.00
IF-MIB::ifNumber.0 = INTEGER: 2
IF-MIB::ifIndex.1 = INTEGER: 1
IF-MIB::ifIndex.2 = INTEGER: 2
IF-MIB::ifDescr.1 = STRING: LOOPBACK
IF-MIB::ifDescr.2 = STRING: Ethernet
IF-MIB::ifType.1 = INTEGER: softwareLoopback(24)
IF-MIB::ifType.2 = INTEGER: ethernetCsmacd(6)
IF-MIB::ifMtu.1 = INTEGER: 1500
IF-MIB::ifMtu.2 = INTEGER: 1500
IF-MIB::ifSpeed.1 = Gauge32: 0
IF-MIB::ifSpeed.2 = Gauge32: 10000000
IF-MIB::ifPhysAddress.1 = STRING:
IF-MIB::ifPhysAddress.2 = STRING: ac:e2:d3:49:bb:a1
IF-MIB::ifAdminStatus.1 = INTEGER: up(1)
IF-MIB::ifAdminStatus.2 = INTEGER: up(1)
IF-MIB::ifOperStatus.1 = INTEGER: up(1)
IF-MIB::ifOperStatus.2 = INTEGER: up(1)
IF-MIB::ifLastChange.1 = Timeticks: (0) 0:00:00.00
IF-MIB::ifLastChange.2 = Timeticks: (548) 0:00:05.48
IF-MIB::ifInOctets.1 = Counter32: 309620722
IF-MIB::ifInOctets.2 = Counter32: 2918254166
IF-MIB::ifInUcastPkts.1 = Counter32: 3271387
IF-MIB::ifInUcastPkts.2 = Counter32: 298347
IF-MIB::ifInNUcastPkts.1 = Counter32: 0
IF-MIB::ifInNUcastPkts.2 = Counter32: 9582167
IF-MIB::ifInDiscards.1 = Counter32: 0
IF-MIB::ifInDiscards.2 = Counter32: 0
IF-MIB::ifInErrors.1 = Counter32: 0
IF-MIB::ifInErrors.2 = Counter32: 0
IF-MIB::ifInUnknownProtos.1 = Counter32: 0
IF-MIB::ifInUnknownProtos.2 = Counter32: 22858
IF-MIB::ifOutOctets.1 = Counter32: 312454090
IF-MIB::ifOutOctets.2 = Counter32: 148119409
IF-MIB::ifOutUcastPkts.1 = Counter32: 3271387
IF-MIB::ifOutUcastPkts.2 = Counter32: 335662
IF-MIB::ifOutNUcastPkts.1 = Counter32: 0
IF-MIB::ifOutNUcastPkts.2 = Counter32: 37266
IF-MIB::ifOutDiscards.1 = Counter32: 0
IF-MIB::ifOutDiscards.2 = Counter32: 0
IF-MIB::ifOutErrors.1 = Counter32: 0
IF-MIB::ifOutErrors.2 = Counter32: 0
IF-MIB::ifOutQLen.1 = Gauge32: 0
IF-MIB::ifOutQLen.2 = Gauge32: 0
IF-MIB::ifSpecific.1 = OID: SNMPv2-SMI::zeroDotZero
IF-MIB::ifSpecific.2 = OID: SNMPv2-SMI::zeroDotZero
SNMPv2-SMI::mib-2.3.1.1.1.2.1.192.168.40.54 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.1.2.1.192.168.41.6 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.1.2.1.192.168.41.19 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.1.2.1.192.168.41.31 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.1.2.1.192.168.41.34 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.1.2.1.192.168.41.49 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.1.2.1.192.168.41.93 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.1.2.1.192.168.41.100 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.1.2.1.192.168.41.212 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.1.2.1.192.168.41.222 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.1.2.1.192.168.42.11 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.1.2.1.192.168.47.160 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.1.2.1.192.168.47.172 = INTEGER: 2
SNMPv2-SMI::mib-2.3.1.1.2.2.1.192.168.40.54 = Hex-STRING: 00 50 56 A8 E0 91
SNMPv2-SMI::mib-2.3.1.1.2.2.1.192.168.41.6 = Hex-STRING: 90 61 AE FD 8D 6F
SNMPv2-SMI::mib-2.3.1.1.2.2.1.192.168.41.19 = Hex-STRING: 50 7B 9D 9E F8 61
SNMPv2-SMI::mib-2.3.1.1.2.2.1.192.168.41.31 = Hex-STRING: 88 B1 11 39 36 27
SNMPv2-SMI::mib-2.3.1.1.2.2.1.192.168.41.34 = Hex-STRING: E4 A4 71 6E 3B 10
SNMPv2-SMI::mib-2.3.1.1.2.2.1.192.168.41.49 = Hex-STRING: 84 A9 3E AD DF 5B
SNMPv2-SMI::mib-2.3.1.1.2.2.1.192.168.41.93 = Hex-STRING: D0 50 99 90 CC 00
SNMPv2-SMI::mib-2.3.1.1.2.2.1.192.168.41.100 = Hex-STRING: 10 E7 C6 1F 97 75
SNMPv2-SMI::mib-2.3.1.1.2.2.1.192.168.41.212 = Hex-STRING: 68 EC C5 51 A6 12
SNMPv2-SMI::mib-2.3.1.1.2.2.1.192.168.41.222 = Hex-STRING: 00 24 9B 2C D4 45
SNMPv2-SMI::mib-2.3.1.1.2.2.1.192.168.42.11 = Hex-STRING: 9C EB E8 67 32 88
SNMPv2-SMI::mib-2.3.1.1.2.2.1.192.168.47.160 = Hex-STRING: 58 0A 20 87 97 4F
SNMPv2-SMI::mib-2.3.1.1.2.2.1.192.168.47.172 = Hex-STRING: 58 0A 20 87 95 DA
SNMPv2-SMI::mib-2.3.1.1.3.2.1.192.168.40.54 = IpAddress: 192.168.40.54
SNMPv2-SMI::mib-2.3.1.1.3.2.1.192.168.41.6 = IpAddress: 192.168.41.6
SNMPv2-SMI::mib-2.3.1.1.3.2.1.192.168.41.19 = IpAddress: 192.168.41.19
SNMPv2-SMI::mib-2.3.1.1.3.2.1.192.168.41.31 = IpAddress: 192.168.41.31
SNMPv2-SMI::mib-2.3.1.1.3.2.1.192.168.41.34 = IpAddress: 192.168.41.34
SNMPv2-SMI::mib-2.3.1.1.3.2.1.192.168.41.49 = IpAddress: 192.168.41.49
SNMPv2-SMI::mib-2.3.1.1.3.2.1.192.168.41.93 = IpAddress: 192.168.41.93
SNMPv2-SMI::mib-2.3.1.1.3.2.1.192.168.41.100 = IpAddress: 192.168.41.100
SNMPv2-SMI::mib-2.3.1.1.3.2.1.192.168.41.212 = IpAddress: 192.168.41.212
SNMPv2-SMI::mib-2.3.1.1.3.2.1.192.168.41.222 = IpAddress: 192.168.41.222
SNMPv2-SMI::mib-2.3.1.1.3.2.1.192.168.42.11 = IpAddress: 192.168.42.11
SNMPv2-SMI::mib-2.3.1.1.3.2.1.192.168.47.160 = IpAddress: 192.168.47.160
SNMPv2-SMI::mib-2.3.1.1.3.2.1.192.168.47.172 = IpAddress: 192.168.47.172
IP-MIB::ipForwarding.0 = INTEGER: notForwarding(2)
IP-MIB::ipDefaultTTL.0 = INTEGER: 64
IP-MIB::ipInReceives.0 = Counter32: 9792396
IP-MIB::ipInHdrErrors.0 = Counter32: 0
IP-MIB::ipInAddrErrors.0 = Counter32: 10751
IP-MIB::ipForwDatagrams.0 = Counter32: 0
IP-MIB::ipInUnknownProtos.0 = Counter32: 0
IP-MIB::ipInDiscards.0 = Counter32: 0
IP-MIB::ipInDelivers.0 = Counter32: 9778433
IP-MIB::ipOutRequests.0 = Counter32: 251764
IP-MIB::ipOutDiscards.0 = Counter32: 0
IP-MIB::ipOutNoRoutes.0 = Counter32: 1
IP-MIB::ipReasmTimeout.0 = INTEGER: 64 seconds
IP-MIB::ipReasmReqds.0 = Counter32: 6436
IP-MIB::ipReasmOKs.0 = Counter32: 3218
IP-MIB::ipReasmFails.0 = Counter32: 0
IP-MIB::ipFragOKs.0 = Counter32: 4136
IP-MIB::ipFragFails.0 = Counter32: 0
IP-MIB::ipFragCreates.0 = Counter32: 1056
IP-MIB::ipAdEntAddr.[IP] = IpAddress: [IP]
IP-MIB::ipAdEntIfIndex.[IP] = INTEGER: 2
IP-MIB::ipAdEntNetMask. [IP] = IpAddress: 0.0.0.0
IP-MIB::ipAdEntBcastAddr. [IP] = INTEGER: 1
IP-MIB::ipAdEntReasmMaxSize. [IP] = INTEGER: 1500
IP-MIB::ip.21.1.1.0.0.0.0 = IpAddress: 0.0.0.0
IP-MIB::ip.21.1.1.127.0.0.1 = IpAddress: 127.0.0.1
IP-MIB::ip.21.1.1.192.168.40.0 = IpAddress: 192.168.40.0
IP-MIB::ip.21.1.2.0.0.0.0 = INTEGER: 2
IP-MIB::ip.21.1.2.127.0.0.1 = INTEGER: 1
IP-MIB::ip.21.1.2.192.168.40.0 = INTEGER: 2
IP-MIB::ip.21.1.3.0.0.0.0 = INTEGER: 1
IP-MIB::ip.21.1.3.127.0.0.1 = INTEGER: 0
IP-MIB::ip.21.1.3.192.168.40.0 = INTEGER: 0
IP-MIB::ip.21.1.4.0.0.0.0 = INTEGER: -1
IP-MIB::ip.21.1.4.127.0.0.1 = INTEGER: -1
IP-MIB::ip.21.1.4.192.168.40.0 = INTEGER: -1
IP-MIB::ip.21.1.5.0.0.0.0 = INTEGER: -1
IP-MIB::ip.21.1.5.127.0.0.1 = INTEGER: -1
IP-MIB::ip.21.1.5.192.168.40.0 = INTEGER: -1
IP-MIB::ip.21.1.6.0.0.0.0 = INTEGER: -1
IP-MIB::ip.21.1.6.127.0.0.1 = INTEGER: -1
IP-MIB::ip.21.1.6.192.168.40.0 = INTEGER: -1
IP-MIB::ip.21.1.7.0.0.0.0 = IpAddress: 0.0.0.0
IP-MIB::ip.21.1.7.127.0.0.1 = IpAddress: 0.0.0.0
IP-MIB::ip.21.1.7.192.168.40.0 = IpAddress: 0.0.0.0
IP-MIB::ip.21.1.8.0.0.0.0 = INTEGER: 4
IP-MIB::ip.21.1.8.127.0.0.1 = INTEGER: 3
IP-MIB::ip.21.1.8.192.168.40.0 = INTEGER: 3
IP-MIB::ip.21.1.9.0.0.0.0 = INTEGER: 2
IP-MIB::ip.21.1.9.127.0.0.1 = INTEGER: 2
IP-MIB::ip.21.1.9.192.168.40.0 = INTEGER: 2
IP-MIB::ip.21.1.10.0.0.0.0 = INTEGER: -1
IP-MIB::ip.21.1.10.127.0.0.1 = INTEGER: -1
IP-MIB::ip.21.1.10.192.168.40.0 = INTEGER: -1
IP-MIB::ip.21.1.11.0.0.0.0 = IpAddress: 255.255.255.255
IP-MIB::ip.21.1.11.127.0.0.1 = IpAddress: 255.255.255.255
IP-MIB::ip.21.1.11.192.168.40.0 = IpAddress: 255.255.255.255
IP-MIB::ip.21.1.12.0.0.0.0 = INTEGER: -1
IP-MIB::ip.21.1.12.127.0.0.1 = INTEGER: -1
IP-MIB::ip.21.1.12.192.168.40.0 = INTEGER: -1
IP-MIB::ip.21.1.13.0.0.0.0 = OID: SNMPv2-SMI::zeroDotZero
IP-MIB::ip.21.1.13.127.0.0.1 = OID: SNMPv2-SMI::zeroDotZero
IP-MIB::ip.21.1.13.192.168.40.0 = OID: SNMPv2-SMI::zeroDotZero
IP-MIB::ipNetToMediaIfIndex.2.192.168.40.54 = INTEGER: 2
IP-MIB::ipNetToMediaIfIndex.2.192.168.41.6 = INTEGER: 2
IP-MIB::ipNetToMediaIfIndex.2.192.168.41.19 = INTEGER: 2
IP-MIB::ipNetToMediaIfIndex.2.192.168.41.31 = INTEGER: 2
IP-MIB::ipNetToMediaIfIndex.2.192.168.41.34 = INTEGER: 2
IP-MIB::ipNetToMediaIfIndex.2.192.168.41.49 = INTEGER: 2
IP-MIB::ipNetToMediaIfIndex.2.192.168.41.93 = INTEGER: 2
IP-MIB::ipNetToMediaIfIndex.2.192.168.41.100 = INTEGER: 2
IP-MIB::ipNetToMediaIfIndex.2.192.168.41.212 = INTEGER: 2
IP-MIB::ipNetToMediaIfIndex.2.192.168.41.222 = INTEGER: 2
IP-MIB::ipNetToMediaIfIndex.2.192.168.42.11 = INTEGER: 2
IP-MIB::ipNetToMediaIfIndex.2.192.168.47.160 = INTEGER: 2
IP-MIB::ipNetToMediaIfIndex.2.192.168.47.172 = INTEGER: 2
IP-MIB::ipNetToMediaPhysAddress.2.192.168.40.54 = STRING: 0:50:56:a8:e0:91
IP-MIB::ipNetToMediaPhysAddress.2.192.168.41.6 = STRING: 90:61:ae:fd:8d:6f
IP-MIB::ipNetToMediaPhysAddress.2.192.168.41.19 = STRING: 50:7b:9d:9e:f8:61
IP-MIB::ipNetToMediaPhysAddress.2.192.168.41.31 = STRING: 88:b1:11:39:36:27
IP-MIB::ipNetToMediaPhysAddress.2.192.168.41.34 = STRING: e4:a4:71:6e:3b:10
IP-MIB::ipNetToMediaPhysAddress.2.192.168.41.49 = STRING: 84:a9:3e:ad:df:5b
IP-MIB::ipNetToMediaPhysAddress.2.192.168.41.93 = STRING: d0:50:99:90:cc:0
IP-MIB::ipNetToMediaPhysAddress.2.192.168.41.100 = STRING: 10:e7:c6:1f:97:75
IP-MIB::ipNetToMediaPhysAddress.2.192.168.41.212 = STRING: 68:ec:c5:51:a6:12
IP-MIB::ipNetToMediaPhysAddress.2.192.168.41.222 = STRING: 0:24:9b:2c:d4:45
IP-MIB::ipNetToMediaPhysAddress.2.192.168.42.11 = STRING: 9c:eb:e8:67:32:88
IP-MIB::ipNetToMediaPhysAddress.2.192.168.47.160 = STRING: 58:a:20:87:97:4f
IP-MIB::ipNetToMediaPhysAddress.2.192.168.47.172 = STRING: 58:a:20:87:95:da
IP-MIB::ipNetToMediaNetAddress.2.192.168.40.54 = IpAddress: 192.168.40.54
IP-MIB::ipNetToMediaNetAddress.2.192.168.41.6 = IpAddress: 192.168.41.6
IP-MIB::ipNetToMediaNetAddress.2.192.168.41.19 = IpAddress: 192.168.41.19
IP-MIB::ipNetToMediaNetAddress.2.192.168.41.31 = IpAddress: 192.168.41.31
IP-MIB::ipNetToMediaNetAddress.2.192.168.41.34 = IpAddress: 192.168.41.34
IP-MIB::ipNetToMediaNetAddress.2.192.168.41.49 = IpAddress: 192.168.41.49
IP-MIB::ipNetToMediaNetAddress.2.192.168.41.93 = IpAddress: 192.168.41.93
IP-MIB::ipNetToMediaNetAddress.2.192.168.41.100 = IpAddress: 192.168.41.100
IP-MIB::ipNetToMediaNetAddress.2.192.168.41.212 = IpAddress: 192.168.41.212
IP-MIB::ipNetToMediaNetAddress.2.192.168.41.222 = IpAddress: 192.168.41.222
IP-MIB::ipNetToMediaNetAddress.2.192.168.42.11 = IpAddress: 192.168.42.11
IP-MIB::ipNetToMediaNetAddress.2.192.168.47.160 = IpAddress: 192.168.47.160
IP-MIB::ipNetToMediaNetAddress.2.192.168.47.172 = IpAddress: 192.168.47.172
IP-MIB::ipNetToMediaType.2.192.168.40.54 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.2.192.168.41.6 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.2.192.168.41.19 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.2.192.168.41.31 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.2.192.168.41.34 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.2.192.168.41.49 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.2.192.168.41.93 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.2.192.168.41.100 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.2.192.168.41.212 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.2.192.168.41.222 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.2.192.168.42.11 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.2.192.168.47.160 = INTEGER: dynamic(3)
IP-MIB::ipNetToMediaType.2.192.168.47.172 = INTEGER: dynamic(3)
IP-MIB::ipRoutingDiscards.0 = Counter32: 0
IP-MIB::ipv4InterfaceReasmMaxSize.1 = INTEGER: 1500
IP-MIB::ipv4InterfaceReasmMaxSize.2 = INTEGER: 1500
IP-MIB::ipv4InterfaceEnableStatus.1 = INTEGER: up(1)
IP-MIB::ipv4InterfaceEnableStatus.2 = INTEGER: up(1)
IP-MIB::ipv6InterfaceReasmMaxSize.1 = Gauge32: 1500 octets
IP-MIB::ipv6InterfaceReasmMaxSize.2 = Gauge32: 1500 octets
IP-MIB::ipv6InterfaceIdentifier.1 = STRING:
IP-MIB::ipv6InterfaceIdentifier.2 = STRING:
IP-MIB::ipv6InterfaceEntry.4.1 = ""
IP-MIB::ipv6InterfaceEntry.4.2 = Hex-STRING: AC E2 D3 49 BB A1
IP-MIB::ipv6InterfaceEnableStatus.1 = INTEGER: up(1)
IP-MIB::ipv6InterfaceEnableStatus.2 = INTEGER: up(1)
IP-MIB::ipv6InterfaceReachableTime.1 = Gauge32: 23081 milliseconds
IP-MIB::ipv6InterfaceReachableTime.2 = Gauge32: 26074 milliseconds
IP-MIB::ipv6InterfaceRetransmitTime.1 = Gauge32: 0 milliseconds
IP-MIB::ipv6InterfaceRetransmitTime.2 = Gauge32: 0 milliseconds
IP-MIB::ipSystemStatsInReceives.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInReceives.ipv6 = Counter32: 5076134
IP-MIB::ipSystemStatsHCInReceives.ipv4 = Counter64: 0
IP-MIB::ipSystemStatsHCInReceives.ipv6 = Counter64: 5076134
IP-MIB::ipSystemStatsInOctets.ipv4 = Counter32: 3227893125
IP-MIB::ipSystemStatsInOctets.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsHCInOctets.ipv4 = Counter64: 3227893301
IP-MIB::ipSystemStatsHCInOctets.ipv6 = Counter64: 0
IP-MIB::ipSystemStatsInHdrErrors.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInHdrErrors.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsInNoRoutes.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInNoRoutes.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsInAddrErrors.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInAddrErrors.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsInUnknownProtos.ipv4 = Counter32: 22858
IP-MIB::ipSystemStatsInUnknownProtos.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsInTruncatedPkts.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInTruncatedPkts.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsInForwDatagrams.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInForwDatagrams.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsHCInForwDatagrams.ipv4 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipSystemStatsHCInForwDatagrams.ipv6 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipSystemStatsReasmReqds.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsReasmReqds.ipv6 = Counter32: 1001
IP-MIB::ipSystemStatsReasmOKs.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsReasmOKs.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsReasmFails.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsReasmFails.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsInDiscards.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInDiscards.ipv6 = Counter32: 5066437
IP-MIB::ipSystemStatsInDelivers.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInDelivers.ipv6 = Counter32: 3371672
IP-MIB::ipSystemStatsHCInDelivers.ipv4 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipSystemStatsHCInDelivers.ipv6 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipSystemStatsOutRequests.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsOutRequests.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsHCOutRequests.ipv4 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipSystemStatsHCOutRequests.ipv6 = Wrong Type (should be Counter64): Counter32: 240
IP-MIB::ipSystemStatsOutNoRoutes.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsOutNoRoutes.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsOutForwDatagrams.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsOutForwDatagrams.ipv6 = Counter32: 1980
IP-MIB::ipSystemStatsHCOutForwDatagrams.ipv4 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipSystemStatsHCOutForwDatagrams.ipv6 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipSystemStatsOutDiscards.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsOutDiscards.ipv6 = Counter32: 3960
IP-MIB::ipSystemStatsOutFragReqds.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsOutFragReqds.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsOutFragOKs.ipv4 = Wrong Type (should be Counter32): Counter64: 0
IP-MIB::ipSystemStatsOutFragOKs.ipv6 = Wrong Type (should be Counter32): Counter64: 0
IP-MIB::ipSystemStatsOutFragFails.ipv4 = Counter32: 460597047
IP-MIB::ipSystemStatsOutFragFails.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsOutFragCreates.ipv4 = Wrong Type (should be Counter32): Counter64: 460597244
IP-MIB::ipSystemStatsOutFragCreates.ipv6 = Wrong Type (should be Counter32): Counter64: 0
IP-MIB::ipSystemStatsOutTransmits.ipv4 = Counter32: 5671439
IP-MIB::ipSystemStatsOutTransmits.ipv6 = Counter32: 1721789
IP-MIB::ipSystemStatsHCOutTransmits.ipv4 = Counter64: 5671439
IP-MIB::ipSystemStatsHCOutTransmits.ipv6 = Counter64: 1721789
IP-MIB::ipSystemStatsOutOctets.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsOutOctets.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsHCOutOctets.ipv4 = Counter64: 0
IP-MIB::ipSystemStatsHCOutOctets.ipv6 = Counter64: 0
IP-MIB::ipSystemStatsInMcastPkts.ipv4 = Counter32: 30043
IP-MIB::ipSystemStatsInMcastPkts.ipv6 = Counter32: 23162
IP-MIB::ipSystemStatsHCInMcastPkts.ipv4 = Counter64: 30043
IP-MIB::ipSystemStatsHCInMcastPkts.ipv6 = Counter64: 23162
IP-MIB::ipSystemStatsInMcastOctets.ipv4 = Counter32: 0
IP-MIB::ipSystemStatsInMcastOctets.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsHCInMcastOctets.ipv4 = Counter64: 0
IP-MIB::ipSystemStatsHCInMcastOctets.ipv6 = Counter64: 0
IP-MIB::ipSystemStatsOutMcastPkts.ipv4 = Counter32: 3910729
IP-MIB::ipSystemStatsOutMcastPkts.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsHCOutMcastPkts.ipv4 = Counter64: 3910729
IP-MIB::ipSystemStatsHCOutMcastPkts.ipv6 = Counter64: 0
IP-MIB::ipSystemStatsOutMcastOctets.ipv4 = Counter32: 7223
IP-MIB::ipSystemStatsOutMcastOctets.ipv6 = Counter32: 0
IP-MIB::ipSystemStatsHCOutMcastOctets.ipv4 = Counter64: 7223
IP-MIB::ipSystemStatsHCOutMcastOctets.ipv6 = Counter64: 0
IP-MIB::ipSystemStatsInBcastPkts.ipv4 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipSystemStatsInBcastPkts.ipv6 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipSystemStatsHCInBcastPkts.ipv4 = Wrong Type (should be Counter64): INTEGER: 0
IP-MIB::ipSystemStatsHCInBcastPkts.ipv6 = Wrong Type (should be Counter64): INTEGER: 0
IP-MIB::ipIfStatsInReceives.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsInReceives.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsInReceives.ipv6.1 = Counter32: 3264719
IP-MIB::ipIfStatsInReceives.ipv6.2 = Counter32: 1811415
IP-MIB::ipIfStatsHCInReceives.ipv4.1 = Counter64: 0
IP-MIB::ipIfStatsHCInReceives.ipv4.2 = Counter64: 0
IP-MIB::ipIfStatsHCInReceives.ipv6.1 = Counter64: 3264719
IP-MIB::ipIfStatsHCInReceives.ipv6.2 = Counter64: 1811415
IP-MIB::ipIfStatsInOctets.ipv4.1 = Counter32: 309620722
IP-MIB::ipIfStatsInOctets.ipv4.2 = Counter32: 2918280128
IP-MIB::ipIfStatsInOctets.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsInOctets.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsHCInOctets.ipv4.1 = Counter64: 309620722
IP-MIB::ipIfStatsHCInOctets.ipv4.2 = Counter64: 2918280484
IP-MIB::ipIfStatsHCInOctets.ipv6.1 = Counter64: 0
IP-MIB::ipIfStatsHCInOctets.ipv6.2 = Counter64: 0
IP-MIB::ipIfStatsInHdrErrors.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsInHdrErrors.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsInHdrErrors.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsInHdrErrors.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsInNoRoutes.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsInNoRoutes.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsInNoRoutes.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsInNoRoutes.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsInAddrErrors.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsInAddrErrors.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsInAddrErrors.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsInAddrErrors.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsInUnknownProtos.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsInUnknownProtos.ipv4.2 = Counter32: 22858
IP-MIB::ipIfStatsInUnknownProtos.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsInUnknownProtos.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsInTruncatedPkts.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsInTruncatedPkts.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsInTruncatedPkts.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsInTruncatedPkts.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsInForwDatagrams.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsInForwDatagrams.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsInForwDatagrams.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsInForwDatagrams.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsHCInForwDatagrams.ipv4.1 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsHCInForwDatagrams.ipv4.2 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsHCInForwDatagrams.ipv6.1 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsHCInForwDatagrams.ipv6.2 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsReasmReqds.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsReasmReqds.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsReasmReqds.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsReasmReqds.ipv6.2 = Counter32: 1001
IP-MIB::ipIfStatsReasmOKs.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsReasmOKs.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsReasmOKs.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsReasmOKs.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsReasmFails.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsReasmFails.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsReasmFails.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsReasmFails.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsInDiscards.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsInDiscards.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsInDiscards.ipv6.1 = Counter32: 3264719
IP-MIB::ipIfStatsInDiscards.ipv6.2 = Counter32: 1801718
IP-MIB::ipIfStatsInDelivers.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsInDelivers.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsInDelivers.ipv6.1 = Counter32: 3264719
IP-MIB::ipIfStatsInDelivers.ipv6.2 = Counter32: 106953
IP-MIB::ipIfStatsHCInDelivers.ipv4.1 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsHCInDelivers.ipv4.2 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsHCInDelivers.ipv6.1 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsHCInDelivers.ipv6.2 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsOutRequests.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsOutRequests.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsOutRequests.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsOutRequests.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsHCOutRequests.ipv4.1 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsHCOutRequests.ipv4.2 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsHCOutRequests.ipv6.1 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsHCOutRequests.ipv6.2 = Wrong Type (should be Counter64): Counter32: 240
IP-MIB::ipIfStatsEntry.22.1.1 = Counter32: 0
IP-MIB::ipIfStatsEntry.22.1.2 = Counter32: 0
IP-MIB::ipIfStatsEntry.22.2.1 = Counter32: 0
IP-MIB::ipIfStatsEntry.22.2.2 = Counter32: 0
IP-MIB::ipIfStatsOutForwDatagrams.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsOutForwDatagrams.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsOutForwDatagrams.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsOutForwDatagrams.ipv6.2 = Counter32: 1980
IP-MIB::ipIfStatsHCOutForwDatagrams.ipv4.1 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsHCOutForwDatagrams.ipv4.2 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsHCOutForwDatagrams.ipv6.1 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsHCOutForwDatagrams.ipv6.2 = Wrong Type (should be Counter64): Counter32: 0
IP-MIB::ipIfStatsOutDiscards.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsOutDiscards.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsOutDiscards.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsOutDiscards.ipv6.2 = Counter32: 3960
IP-MIB::ipIfStatsOutFragReqds.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsOutFragReqds.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsOutFragReqds.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsOutFragReqds.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsOutFragOKs.ipv4.1 = Wrong Type (should be Counter32): Counter64: 0
IP-MIB::ipIfStatsOutFragOKs.ipv4.2 = Wrong Type (should be Counter32): Counter64: 0
IP-MIB::ipIfStatsOutFragOKs.ipv6.1 = Wrong Type (should be Counter32): Counter64: 0
IP-MIB::ipIfStatsOutFragOKs.ipv6.2 = Wrong Type (should be Counter32): Counter64: 0
IP-MIB::ipIfStatsOutFragFails.ipv4.1 = Counter32: 312454090
IP-MIB::ipIfStatsOutFragFails.ipv4.2 = Counter32: 148156021
IP-MIB::ipIfStatsOutFragFails.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsOutFragFails.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsOutFragCreates.ipv4.1 = Wrong Type (should be Counter32): Counter64: 312454090
IP-MIB::ipIfStatsOutFragCreates.ipv4.2 = Wrong Type (should be Counter32): Counter64: 148156419
IP-MIB::ipIfStatsOutFragCreates.ipv6.1 = Wrong Type (should be Counter32): Counter64: 0
IP-MIB::ipIfStatsOutFragCreates.ipv6.2 = Wrong Type (should be Counter32): Counter64: 0
IP-MIB::ipIfStatsOutTransmits.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsOutTransmits.ipv4.2 = Counter32: 5671439
IP-MIB::ipIfStatsOutTransmits.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsOutTransmits.ipv6.2 = Counter32: 1721789
IP-MIB::ipIfStatsHCOutTransmits.ipv4.1 = Counter64: 0
IP-MIB::ipIfStatsHCOutTransmits.ipv4.2 = Counter64: 5671439
IP-MIB::ipIfStatsHCOutTransmits.ipv6.1 = Counter64: 0
IP-MIB::ipIfStatsHCOutTransmits.ipv6.2 = Counter64: 1721789
IP-MIB::ipIfStatsOutOctets.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsOutOctets.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsOutOctets.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsOutOctets.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsHCOutOctets.ipv4.1 = Counter64: 0
IP-MIB::ipIfStatsHCOutOctets.ipv4.2 = Counter64: 0
IP-MIB::ipIfStatsHCOutOctets.ipv6.1 = Counter64: 0
IP-MIB::ipIfStatsHCOutOctets.ipv6.2 = Counter64: 0
IP-MIB::ipIfStatsInMcastPkts.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsInMcastPkts.ipv4.2 = Counter32: 30043
IP-MIB::ipIfStatsInMcastPkts.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsInMcastPkts.ipv6.2 = Counter32: 23162
IP-MIB::ipIfStatsHCInMcastPkts.ipv4.1 = Counter64: 0
IP-MIB::ipIfStatsHCInMcastPkts.ipv4.2 = Counter64: 30043
IP-MIB::ipIfStatsHCInMcastPkts.ipv6.1 = Counter64: 0
IP-MIB::ipIfStatsHCInMcastPkts.ipv6.2 = Counter64: 23162
IP-MIB::ipIfStatsInMcastOctets.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsInMcastOctets.ipv4.2 = Counter32: 0
IP-MIB::ipIfStatsInMcastOctets.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsInMcastOctets.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsHCInMcastOctets.ipv4.1 = Counter64: 0
IP-MIB::ipIfStatsHCInMcastOctets.ipv4.2 = Counter64: 0
IP-MIB::ipIfStatsHCInMcastOctets.ipv6.1 = Counter64: 0
IP-MIB::ipIfStatsHCInMcastOctets.ipv6.2 = Counter64: 0
IP-MIB::ipIfStatsOutMcastPkts.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsOutMcastPkts.ipv4.2 = Counter32: 3910729
IP-MIB::ipIfStatsOutMcastPkts.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsOutMcastPkts.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsHCOutMcastPkts.ipv4.1 = Counter64: 0
IP-MIB::ipIfStatsHCOutMcastPkts.ipv4.2 = Counter64: 3910729
IP-MIB::ipIfStatsHCOutMcastPkts.ipv6.1 = Counter64: 0
IP-MIB::ipIfStatsHCOutMcastPkts.ipv6.2 = Counter64: 0
IP-MIB::ipIfStatsOutMcastOctets.ipv4.1 = Counter32: 0
IP-MIB::ipIfStatsOutMcastOctets.ipv4.2 = Counter32: 7223
IP-MIB::ipIfStatsOutMcastOctets.ipv6.1 = Counter32: 0
IP-MIB::ipIfStatsOutMcastOctets.ipv6.2 = Counter32: 0
IP-MIB::ipIfStatsHCOutMcastOctets.ipv4.1 = Counter64: 0
IP-MIB::ipIfStatsHCOutMcastOctets.ipv4.2 = Counter64: 7223
IP-MIB::ipIfStatsHCOutMcastOctets.ipv6.1 = Counter64: 0
IP-MIB::ipIfStatsHCOutMcastOctets.ipv6.2 = Counter64: 0
IP-MIB::ipIfStatsInBcastPkts.ipv4.1 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipIfStatsInBcastPkts.ipv4.2 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipIfStatsInBcastPkts.ipv6.1 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipIfStatsInBcastPkts.ipv6.2 = Wrong Type (should be Counter32): INTEGER: 0
IP-MIB::ipIfStatsHCInBcastPkts.ipv4.1 = Wrong Type (should be Counter64): INTEGER: 0
IP-MIB::ipIfStatsHCInBcastPkts.ipv4.2 = Wrong Type (should be Counter64): INTEGER: 0
IP-MIB::ipIfStatsHCInBcastPkts.ipv6.1 = Wrong Type (should be Counter64): INTEGER: 0
IP-MIB::ipIfStatsHCInBcastPkts.ipv6.2 = Wrong Type (should be Counter64): INTEGER: 0
IP-MIB::ipAddressSpinLock.1.3.1.4.127.0.0.1 = INTEGER: 1
IP-MIB::ipAddressSpinLock.1.3.1.4.[IP] = INTEGER: 2
IP-MIB::ipAddressSpinLock.1.4.1.4.127.0.0.1 = INTEGER: 1
IP-MIB::ipAddressSpinLock.1.4.1.4.[IP] = INTEGER: 1
IP-MIB::ipAddressSpinLock.1.6.1.4.127.0.0.1 = INTEGER: 2
IP-MIB::ipAddressSpinLock.1.6.1.4.[IP] = INTEGER: 2
IP-MIB::ipAddressSpinLock.1.7.1.4.127.0.0.1 = INTEGER: 1
IP-MIB::ipAddressSpinLock.1.7.1.4.[IP] = INTEGER: 1
IP-MIB::ipAddressSpinLock.1.8.1.4.127.0.0.1 = INTEGER: 0
IP-MIB::ipAddressSpinLock.1.8.1.4.[IP] = INTEGER: 0
IP-MIB::ipAddressSpinLock.1.9.1.4.127.0.0.1 = INTEGER: 0
IP-MIB::ipAddressSpinLock.1.9.1.4.[IP] = INTEGER: 0
IP-MIB::ipAddressType.ipv6.".".192.168.40.54 = Wrong Type (should be INTEGER): Hex-STRING: 00 50 56 A8 E0 91
IP-MIB::ipAddressType.ipv6.".".192.168.41.6 = Wrong Type (should be INTEGER): Hex-STRING: 90 61 AE FD 8D 6F
IP-MIB::ipAddressType.ipv6.".".192.168.41.19 = Wrong Type (should be INTEGER): Hex-STRING: 50 7B 9D 9E F8 61
IP-MIB::ipAddressType.ipv6.".".192.168.41.31 = Wrong Type (should be INTEGER): Hex-STRING: 88 B1 11 39 36 27
IP-MIB::ipAddressType.ipv6.".".192.168.41.34 = Wrong Type (should be INTEGER): Hex-STRING: E4 A4 71 6E 3B 10
IP-MIB::ipAddressType.ipv6.".".192.168.41.49 = Wrong Type (should be INTEGER): Hex-STRING: 84 A9 3E AD DF 5B
IP-MIB::ipAddressType.ipv6.".".192.168.41.93 = Wrong Type (should be INTEGER): Hex-STRING: D0 50 99 90 CC 00
IP-MIB::ipAddressType.ipv6.".".192.168.41.100 = Wrong Type (should be INTEGER): Hex-STRING: 10 E7 C6 1F 97 75
IP-MIB::ipAddressType.ipv6.".".192.168.41.212 = Wrong Type (should be INTEGER): Hex-STRING: 68 EC C5 51 A6 12
IP-MIB::ipAddressType.ipv6.".".192.168.41.222 = Wrong Type (should be INTEGER): Hex-STRING: 00 24 9B 2C D4 45
IP-MIB::ipAddressType.ipv6.".".192.168.42.11 = Wrong Type (should be INTEGER): Hex-STRING: 9C EB E8 67 32 88
IP-MIB::ipAddressType.ipv6.".".192.168.47.160 = Wrong Type (should be INTEGER): Hex-STRING: 58 0A 20 87 97 4F
IP-MIB::ipAddressType.ipv6.".".192.168.47.172 = Wrong Type (should be INTEGER): Hex-STRING: 58 0A 20 87 95 DA
IP-MIB::ipAddressPrefix.ipv6.".".192.168.40.54 = Wrong Type (should be OBJECT IDENTIFIER): INTEGER: 0
IP-MIB::ipAddressPrefix.ipv6.".".192.168.41.6 = Wrong Type (should be OBJECT IDENTIFIER): INTEGER: 0
IP-MIB::ipAddressPrefix.ipv6.".".192.168.41.19 = Wrong Type (should be OBJECT IDENTIFIER): INTEGER: 0
IP-MIB::ipAddressPrefix.ipv6.".".192.168.41.31 = Wrong Type (should be OBJECT IDENTIFIER): INTEGER: 0
IP-MIB::ipAddressPrefix.ipv6.".".192.168.41.34 = Wrong Type (should be OBJECT IDENTIFIER): INTEGER: 0
IP-MIB::ipAddressPrefix.ipv6.".".192.168.41.49 = Wrong Type (should be OBJECT IDENTIFIER): INTEGER: 0
IP-MIB::ipAddressPrefix.ipv6.".".192.168.41.93 = Wrong Type (should be OBJECT IDENTIFIER): INTEGER: 0
IP-MIB::ipAddressPrefix.ipv6.".".192.168.41.100 = Wrong Type (should be OBJECT IDENTIFIER): INTEGER: 0
IP-MIB::ipAddressPrefix.ipv6.".".192.168.41.212 = Wrong Type (should be OBJECT IDENTIFIER): INTEGER: 0
IP-MIB::ipAddressPrefix.ipv6.".".192.168.41.222 = Wrong Type (should be OBJECT IDENTIFIER): INTEGER: 0
IP-MIB::ipAddressPrefix.ipv6.".".192.168.42.11 = Wrong Type (should be OBJECT IDENTIFIER): INTEGER: 0
IP-MIB::ipAddressPrefix.ipv6.".".192.168.47.160 = Wrong Type (should be OBJECT IDENTIFIER): INTEGER: 0
IP-MIB::ipAddressPrefix.ipv6.".".192.168.47.172 = Wrong Type (should be OBJECT IDENTIFIER): INTEGER: 0
IP-MIB::ipAddressOrigin.ipv6.".".192.168.40.54 = INTEGER: 3
IP-MIB::ipAddressOrigin.ipv6.".".192.168.41.6 = INTEGER: 3
IP-MIB::ipAddressOrigin.ipv6.".".192.168.41.19 = INTEGER: 3
IP-MIB::ipAddressOrigin.ipv6.".".192.168.41.31 = INTEGER: 3
IP-MIB::ipAddressOrigin.ipv6.".".192.168.41.34 = INTEGER: 3
IP-MIB::ipAddressOrigin.ipv6.".".192.168.41.49 = INTEGER: 3
IP-MIB::ipAddressOrigin.ipv6.".".192.168.41.93 = INTEGER: 3
IP-MIB::ipAddressOrigin.ipv6.".".192.168.41.100 = INTEGER: 3
IP-MIB::ipAddressOrigin.ipv6.".".192.168.41.212 = INTEGER: 3
IP-MIB::ipAddressOrigin.ipv6.".".192.168.41.222 = INTEGER: 3
IP-MIB::ipAddressOrigin.ipv6.".".192.168.42.11 = INTEGER: 3
IP-MIB::ipAddressOrigin.ipv6.".".192.168.47.160 = INTEGER: 3
IP-MIB::ipAddressOrigin.ipv6.".".192.168.47.172 = INTEGER: 3
IP-MIB::ipAddressStatus.ipv6.".".192.168.40.54 = INTEGER: 0
IP-MIB::ipAddressStatus.ipv6.".".192.168.41.6 = INTEGER: 0
IP-MIB::ipAddressStatus.ipv6.".".192.168.41.19 = INTEGER: 0
IP-MIB::ipAddressStatus.ipv6.".".192.168.41.31 = INTEGER: 0
IP-MIB::ipAddressStatus.ipv6.".".192.168.41.34 = INTEGER: 0
IP-MIB::ipAddressStatus.ipv6.".".192.168.41.49 = INTEGER: 0
IP-MIB::ipAddressStatus.ipv6.".".192.168.41.93 = INTEGER: 0
IP-MIB::ipAddressStatus.ipv6.".".192.168.41.100 = INTEGER: 0
IP-MIB::ipAddressStatus.ipv6.".".192.168.41.212 = INTEGER: 0
IP-MIB::ipAddressStatus.ipv6.".".192.168.41.222 = INTEGER: 0
IP-MIB::ipAddressStatus.ipv6.".".192.168.42.11 = INTEGER: 0
IP-MIB::ipAddressStatus.ipv6.".".192.168.47.160 = INTEGER: 0
IP-MIB::ipAddressStatus.ipv6.".".192.168.47.172 = INTEGER: 0
IP-MIB::ipNetToPhysicalNetAddressType.1 = INTEGER: unknown(0)
IP-MIB::ipNetToPhysicalNetAddressType.2 = INTEGER: unknown(0)
IP-MIB::ipNetToPhysicalNetAddress.1 = Wrong Type (should be OCTET STRING): INTEGER: 0
IP-MIB::ipNetToPhysicalNetAddress.2 = Wrong Type (should be OCTET STRING): INTEGER: 0
IP-MIB::ipNetToPhysicalPhysAddress.1 = Wrong Type (should be OCTET STRING): INTEGER: 0
IP-MIB::ipNetToPhysicalPhysAddress.2 = Wrong Type (should be OCTET STRING): INTEGER: 0
IP-MIB::ipNetToPhysicalLastUpdated.1 = Wrong Type (should be Timeticks): INTEGER: 0
IP-MIB::ipNetToPhysicalLastUpdated.2 = Wrong Type (should be Timeticks): INTEGER: 0
IP-MIB::ipNetToPhysicalType.1 = INTEGER: 0
IP-MIB::ipNetToPhysicalType.2 = INTEGER: 0
IP-MIB::ipNetToPhysicalState.1 = INTEGER: 0
IP-MIB::ipNetToPhysicalState.2 = INTEGER: 0
IP-MIB::ipNetToPhysicalRowStatus.1 = INTEGER: 0
IP-MIB::ipNetToPhysicalRowStatus.2 = INTEGER: 0
IP-MIB::ipNetToPhysicalEntry.9.ipv4 = INTEGER: 0
IP-MIB::ipNetToPhysicalEntry.9.ipv6 = INTEGER: 0
IP-MIB::ipNetToPhysicalEntry.10.ipv4 = INTEGER: 0
IP-MIB::ipNetToPhysicalEntry.10.ipv6 = INTEGER: 0
IP-MIB::ipNetToPhysicalEntry.11.ipv4 = INTEGER: 0
IP-MIB::ipNetToPhysicalEntry.11.ipv6 = INTEGER: 0
IP-MIB::ipNetToPhysicalEntry.12.ipv4 = INTEGER: 0
IP-MIB::ipNetToPhysicalEntry.12.ipv6 = INTEGER: 0
IP-MIB::ipNetToPhysicalEntry.13.ipv4 = INTEGER: 0
IP-MIB::ipNetToPhysicalEntry.13.ipv6 = INTEGER: 0
IP-MIB::ipDefaultRouterTable.0 = INTEGER: 0
IP-MIB::ipv6RouterAdvertSpinLock.1.2.1 = INTEGER: 0
IP-MIB::ipv6RouterAdvertSpinLock.1.2.2 = INTEGER: 0
IP-MIB::ipv6RouterAdvertSpinLock.1.3.1 = INTEGER: 1000
IP-MIB::ipv6RouterAdvertSpinLock.1.3.2 = INTEGER: 1000
IP-MIB::ipv6RouterAdvertSpinLock.1.4.1 = INTEGER: 0
IP-MIB::ipv6RouterAdvertSpinLock.1.4.2 = INTEGER: 0
IP-MIB::ipv6RouterAdvertSpinLock.1.5.1 = INTEGER: 0
IP-MIB::ipv6RouterAdvertSpinLock.1.5.2 = INTEGER: 0
IP-MIB::ipv6RouterAdvertSpinLock.1.6.1 = INTEGER: 0
IP-MIB::ipv6RouterAdvertSpinLock.1.6.2 = INTEGER: 0
IP-MIB::ipv6RouterAdvertSpinLock.1.7.1 = INTEGER: 1500
IP-MIB::ipv6RouterAdvertSpinLock.1.7.2 = INTEGER: 1500
IP-MIB::ipv6RouterAdvertSpinLock.1.8.1 = INTEGER: 23081
IP-MIB::ipv6RouterAdvertSpinLock.1.8.2 = INTEGER: 26074
IP-MIB::ipv6RouterAdvertSpinLock.1.9.1 = INTEGER: 4000
IP-MIB::ipv6RouterAdvertSpinLock.1.9.2 = INTEGER: 4000
IP-MIB::ipv6RouterAdvertSpinLock.1.10.1 = INTEGER: 64
IP-MIB::ipv6RouterAdvertSpinLock.1.10.2 = INTEGER: 64
IP-MIB::ipv6RouterAdvertSpinLock.1.11.1 = INTEGER: 0
IP-MIB::ipv6RouterAdvertSpinLock.1.11.2 = INTEGER: 0
IP-MIB::ipv6RouterAdvertSpinLock.1.12.1 = INTEGER: 0
IP-MIB::ipv6RouterAdvertSpinLock.1.12.2 = INTEGER: 0
IP-MIB::icmpInMsgs.0 = Counter32: 21835
IP-MIB::icmpInErrors.0 = Counter32: 0
IP-MIB::icmpInDestUnreachs.0 = Counter32: 4
IP-MIB::icmpInTimeExcds.0 = Counter32: 0
IP-MIB::icmpInParmProbs.0 = Counter32: 0
IP-MIB::icmpInSrcQuenchs.0 = Counter32: 0
IP-MIB::icmpInRedirects.0 = Counter32: 0
IP-MIB::icmpInEchos.0 = Counter32: 21831
IP-MIB::icmpInEchoReps.0 = Counter32: 0
IP-MIB::icmpInTimestamps.0 = Counter32: 0
IP-MIB::icmpInTimestampReps.0 = Counter32: 0
IP-MIB::icmpInAddrMasks.0 = Counter32: 0
IP-MIB::icmpInAddrMaskReps.0 = Counter32: 0
IP-MIB::icmpOutMsgs.0 = Counter32: 21837
IP-MIB::icmpOutErrors.0 = Counter32: 0
IP-MIB::icmpOutDestUnreachs.0 = Counter32: 6
IP-MIB::icmpOutTimeExcds.0 = Counter32: 0
IP-MIB::icmpOutParmProbs.0 = Counter32: 0
IP-MIB::icmpOutSrcQuenchs.0 = Counter32: 0
IP-MIB::icmpOutRedirects.0 = Counter32: 0
IP-MIB::icmpOutEchos.0 = Counter32: 0
IP-MIB::icmpOutEchoReps.0 = Counter32: 21831
IP-MIB::icmpOutTimestamps.0 = Counter32: 0
IP-MIB::icmpOutTimestampReps.0 = Counter32: 0
IP-MIB::icmpOutAddrMasks.0 = Counter32: 0
IP-MIB::icmpOutAddrMaskReps.0 = Counter32: 0
IP-MIB::icmp.27.1.2.1 = Counter32: 21835
IP-MIB::icmp.27.1.2.2 = Counter32: 24324
IP-MIB::icmp.27.1.3.1 = Counter32: 0
IP-MIB::icmp.27.1.3.2 = Counter32: 13
IP-MIB::icmp.27.1.4.1 = Counter32: 21837
IP-MIB::icmp.27.1.4.2 = Counter32: 9
IP-MIB::icmp.27.1.5.1 = Counter32: 0
IP-MIB::icmp.27.1.5.2 = Counter32: 0
IP-MIB::icmp.28.1.3.1.0 = Counter32: 0
IP-MIB::icmp.28.1.3.1.3 = Counter32: 4
IP-MIB::icmp.28.1.3.1.4 = Counter32: 0
IP-MIB::icmp.28.1.3.1.5 = Counter32: 0
IP-MIB::icmp.28.1.3.1.8 = Counter32: 21831
IP-MIB::icmp.28.1.3.1.9 = Counter32: 0
IP-MIB::icmp.28.1.3.1.10 = Counter32: 0
IP-MIB::icmp.28.1.3.1.11 = Counter32: 0
IP-MIB::icmp.28.1.3.1.12 = Counter32: 0
IP-MIB::icmp.28.1.3.1.13 = Counter32: 0
IP-MIB::icmp.28.1.3.1.14 = Counter32: 0
IP-MIB::icmp.28.1.3.1.15 = Counter32: 0
IP-MIB::icmp.28.1.3.1.16 = Counter32: 0
IP-MIB::icmp.28.1.3.1.17 = Counter32: 0
IP-MIB::icmp.28.1.3.1.18 = Counter32: 0
IP-MIB::icmp.28.1.3.2.1 = Counter32: 2
IP-MIB::icmp.28.1.3.2.2 = Counter32: 0
IP-MIB::icmp.28.1.3.2.3 = Counter32: 0
IP-MIB::icmp.28.1.3.2.4 = Counter32: 0
IP-MIB::icmp.28.1.3.2.128 = Counter32: 1
IP-MIB::icmp.28.1.3.2.129 = Counter32: 0
IP-MIB::icmp.28.1.3.2.130 = Counter32: 0
IP-MIB::icmp.28.1.3.2.131 = Counter32: 1970
IP-MIB::icmp.28.1.3.2.132 = Counter32: 4635
IP-MIB::icmp.28.1.3.2.133 = Counter32: 0
IP-MIB::icmp.28.1.3.2.134 = Counter32: 0
IP-MIB::icmp.28.1.3.2.135 = Counter32: 3117
IP-MIB::icmp.28.1.3.2.136 = Counter32: 14586
IP-MIB::icmp.28.1.3.2.137 = Counter32: 0
IP-MIB::icmp.28.1.4.1.0 = Counter32: 21831
IP-MIB::icmp.28.1.4.1.3 = Counter32: 6
IP-MIB::icmp.28.1.4.1.4 = Counter32: 0
IP-MIB::icmp.28.1.4.1.5 = Counter32: 0
IP-MIB::icmp.28.1.4.1.8 = Counter32: 0
IP-MIB::icmp.28.1.4.1.9 = Counter32: 0
IP-MIB::icmp.28.1.4.1.10 = Counter32: 0
IP-MIB::icmp.28.1.4.1.11 = Counter32: 0
IP-MIB::icmp.28.1.4.1.12 = Counter32: 0
IP-MIB::icmp.28.1.4.1.13 = Counter32: 0
IP-MIB::icmp.28.1.4.1.14 = Counter32: 0
IP-MIB::icmp.28.1.4.1.15 = Counter32: 0
IP-MIB::icmp.28.1.4.1.16 = Counter32: 0
IP-MIB::icmp.28.1.4.1.17 = Counter32: 0
IP-MIB::icmp.28.1.4.1.18 = Counter32: 0
IP-MIB::icmp.28.1.4.2.1 = Counter32: 0
IP-MIB::icmp.28.1.4.2.2 = Counter32: 0
IP-MIB::icmp.28.1.4.2.3 = Counter32: 0
IP-MIB::icmp.28.1.4.2.4 = Counter32: 0
IP-MIB::icmp.28.1.4.2.128 = Counter32: 0
IP-MIB::icmp.28.1.4.2.129 = Counter32: 0
IP-MIB::icmp.28.1.4.2.130 = Counter32: 0
IP-MIB::icmp.28.1.4.2.131 = Counter32: 8
IP-MIB::icmp.28.1.4.2.132 = Counter32: 0
IP-MIB::icmp.28.1.4.2.133 = Counter32: 0
IP-MIB::icmp.28.1.4.2.134 = Counter32: 0
IP-MIB::icmp.28.1.4.2.135 = Counter32: 0
IP-MIB::icmp.28.1.4.2.136 = Counter32: 0
IP-MIB::icmp.28.1.4.2.137 = Counter32: 0
TCP-MIB::tcpRtoAlgorithm.0 = INTEGER: vanj(4)
TCP-MIB::tcpRtoMin.0 = INTEGER: 1000 milliseconds
TCP-MIB::tcpRtoMax.0 = INTEGER: 60000 milliseconds
TCP-MIB::tcpMaxConn.0 = INTEGER: 128
TCP-MIB::tcpActiveOpens.0 = Counter32: 3669
TCP-MIB::tcpPassiveOpens.0 = Counter32: 24967
TCP-MIB::tcpAttemptFails.0 = Counter32: 899
TCP-MIB::tcpEstabResets.0 = Counter32: 2653
TCP-MIB::tcpCurrEstab.0 = Gauge32: 6
TCP-MIB::tcpInSegs.0 = Counter32: 3490015
TCP-MIB::tcpOutSegs.0 = Counter32: 1736745
TCP-MIB::tcpRetransSegs.0 = Counter32: 1336
TCP-MIB::tcpConnState.0.0.0.0.80.0.0.0.0.0 = INTEGER: listen(2)
TCP-MIB::tcpConnState.0.0.0.0.515.0.0.0.0.0 = INTEGER: listen(2)
TCP-MIB::tcpConnState.0.0.0.0.3910.0.0.0.0.0 = INTEGER: listen(2)
TCP-MIB::tcpConnState.0.0.0.0.3911.0.0.0.0.0 = INTEGER: listen(2)
TCP-MIB::tcpConnState.0.0.0.0.8080.0.0.0.0.0 = INTEGER: listen(2)
TCP-MIB::tcpConnState.0.0.0.0.9100.0.0.0.0.0 = INTEGER: listen(2)
TCP-MIB::tcpConnState.0.0.0.0.9107.0.0.0.0.0 = INTEGER: listen(2)
TCP-MIB::tcpConnLocalAddress.0.0.0.0.80.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnLocalAddress.0.0.0.0.515.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnLocalAddress.0.0.0.0.3910.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnLocalAddress.0.0.0.0.3911.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnLocalAddress.0.0.0.0.8080.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnLocalAddress.0.0.0.0.9100.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnLocalAddress.0.0.0.0.9107.0.0.0.0.0 = IpAddress: 0.0.0.0
TCP-MIB::tcpConnLocalPort.0.0.0.0.80.0.0.0.0.0 = INTEGER: 80
TCP-MIB::tcpConnLocalPort.0.0.0.0.515.0.0.0.0.0 = INTEGER: 515
TCP-MIB::tcpConnLocalPort.0.0.0.0.3910.0.0.0.0.0 = INTEGER: 3910
TCP-MIB::tcpConnLocalPort.0.0.0.0.3911.0.0.0.0.0 = INTEGER: 3911
TCP-MIB::tcpConnLocalPort.0.0.0.0.8080.0.0.0.0.0 = INTEGER: 8080
TCP-MIB::tcpConnLocalPort.0.0.0.0.9100.0.0.0.0.0 = INTEGER: 9100
TCP-MIB::tcpConnLocalPort.0.0.0.0.9107.0.0.0.0.0 = INTEGER: 9107
Had to delete some lines, had max 60 000 character limit.
Best wishes,
Kukkurloom
benjaminsmith
Post
by benjaminsmith » Thu Jul 25, 2019 3:11 pm
Making progress as you are connecting to the printer from the Nagios server. You should be able to run the plugin and get valid return. Go to the plugin directory
/usr/local/nagios/libexec , and run the following command as nagios user.
./check_hpjd -H <ip_address> -C public
There's also the
SNMP printer check plugin available on the
Nagios Exchange .
Privacy Policy .
