Schedule local backups are no longer operational
dlukinski
Post by dlukinski »
Hello XI support
Our XI local backups are no longer being created after 5.6.3 upgrade done (from 5.5.11)
- enabled, configured, but not created
Thank you
Re: Schedule local backups are no longer operational
Go to Admin > Scheduled Backups > Local, schedule a backup to run in a few minutes, and click on "Update Settings". Start a running tail on cmdsubsys.log:
tail -f /usr/local/nagiosxi/var/cmdsubsys.log
to start capturing the output. Wait until the backup is complete, stop the tail (ctrl+c), copy/paste the output on the forum.
Also, enable debugging for schedule backups by modifying the last line in the /usr/local/nagiosxi/html/includes/constants.inc.php file as such:
// Scheduled backups constants
// 0 - Debug, 1 - Info, 2 - Warning, 3 - Error
define('SB_LOGLEVEL', 0);
Save, exit, and restart apache:
service httpd restart
Run a local scheduled backup, then post the /usr/local/nagiosxi/var/components/scheduledbackups.log on the forum.
dlukinski
Post by dlukinski »
lmiltchev wrote:Go to Admin > Scheduled Backups > Local, schedule a backup to run in a few minutes, and click on "Update Settings". Start a running tail on cmdsubsys.log:
Manually triggered backups work, but not the scheduled:
.PROCESSING COMMAND ID 32522...
PROCESS COMMAND: CMD=1117, DATA=a:2:{i:0;s:19:"nagiosxi.1563375901";i:1;s:16:"/mnt/nfs/backup/";}
CMDLINE=sudo /usr/local/nagiosxi/scripts/backup_xi.sh -n nagiosxi.1563375901 -d /mnt/nfs/backup
No entry for terminal type "unknown";
using dumb terminal settings.
Stopping nagios: .done.
Starting nagios: done.
Backing up NagiosQL...
tar: Removing leading `/' from member names
Backing up Nagios Core...
- any way to re-create CRONed backup jobs ?
Can you post the post the /usr/local/nagiosxi/var/components/scheduledbackups.log file from the Nagios server so we can check it for errors?
Scheduled Backups in XI are ran by XI, they are not ran by a cron job.
An entry is setup in the MYSQL database which is read by the cmdsubsys.php script and submitted to run on the system.
To view the settings, run this command.
echo 'select * from xi_options;' | mysql  -t -pnagiosxi nagiosxi |grep backup
dlukinski
Post by dlukinski »
tgriep wrote:Can you post the post the /usr/local/nagiosxi/var/components/scheduledbackups.log file from the Nagios server so we can check it for errors?
Log attached, command results are down below:
[root@fikc-nagxiprod01 components]# echo 'select * from xi_options;' | mysql  -t -pnagiosxi nagiosxi |grep backup
ERROR 1049 (42000): Unknown database 'nagiosxi'
I bet your system is still using the Postgresql database to host the nagiosxi database so run this command instead.
echo 'select * from xi_options;' | psql nagiosxi nagiosxi |grep backup
Run these commands as well and post the output.
ls -l /store/backups
ls -l /store/backups/nagiosxi
The scheduledbackup log file has MYSQL errors so I would like to check the following file to see if the settings are correct for the MYSQL server, get the file and post it here.
/usr/local/nagiosxi/html/config.inc.php
Thanks.
dlukinski
Post by dlukinski »
tgriep wrote:I bet your system is still using the Postgresql database to host the nagiosxi database so run this command instead.
Thanks.
Please see the output and the fle attached
[root@fikc-nagxiprod01 components]# echo 'select * from xi_options;' | psql nagiosxi nagiosxi |grep backup
       154 | bpi_backupfile                                    | /usr/local/nagiosxi/etc/components/bpi.conf.backup
       127 | scheduled_local_backups                           | a:9:{s:6:"active";i:1;s:4:"freq";s:5:"daily";s:3:"day";s:1:"0";s:5:"hours";s:2:"15";s:4:"mins";s:2:"05";s:3:"dir";s:16:"/mnt/nfs/backup/";s:5:"limit";s:2:"15";s:7:"lastrun";i:1563548701;s:7:"nextrun";i:1563635100;}
       128 | scheduledbackups_last_backup_size                 | 4323524362
       125 | scheduled_ftp_backups                             | a:15:{s:6:"active";i:0;s:4:"freq";s:5:"daily";s:3:"day";s:1:"0";s:5:"hours";s:2:"01";s:4:"mins";s:2:"11";s:6:"server";s:11:"10.96.30.30";s:4:"port";s:2:"21";s:8:"username";s:9:"nagiosbkp";s:8:"password";s:40:"1f220470659d344563mEGgi0hCT17hTvhu5qTA==";s:3:"dir";s:15:"/Production/XI/";s:7:"passive";i:1;s:6:"secure";i:0;s:5:"limit";s:2:"33";s:7:"lastrun";s:10:"1501117860";s:7:"nextrun";i:1563412260;}
       126 | scheduled_ssh_backups                             | a:17:{s:6:"active";i:0;s:4:"freq";s:5:"daily";s:3:"day";s:1:"0";s:5:"hours";s:2:"15";s:4:"mins";s:2:"00";s:6:"server";s:13:"10.102.36.163";s:4:"port";s:2:"15";s:8:"username";s:14:"nagiosxibackup";s:8:"password";s:40:"da49ca99b7119383K/79Atvh9y9WZqcLzBgK9Q==";s:9:"auth_type";s:8:"password";s:11:"pubkey_file";s:0:"";s:12:"privkey_file";s:0:"";s:16:"privkey_password";s:0:"";s:3:"dir";s:21:"/home/nagiosxibackup/";s:5:"limit";s:1:"7";s:7:"lastrun";s:10:"1563319381";s:7:"nextrun";i:1563462000;}
You have mail in /var/spool/mail/root
[root@fikc-nagxiprod01 components]# ls -l /store/backups
total 16
drwxr-xr-x 5 root   root   4096 Jul 19 07:04 mysql
drwxr-xr-x 2 nagios nagios 4096 Jul 17 14:33 nagiosxi
drwxr-xr-x 2 root   root   4096 Jun 14 15:10 nagvis
drwxr-xr-x 5 root   root   4096 Jul 19 07:00 postgresql
[root@fikc-nagxiprod01 components]# ls -l /store/backups/nagiosxi
total 40740804
-rw-r--r-- 1 nagios nagios 4170461235 Jun 12 14:51 1560350114.tar.gz
-rw-r--r-- 1 nagios nagios 4185590845 Jun 14 15:08 1560523825.tar.gz
-rw-r--r-- 1 nagios nagios 4276130617 Jul  4 14:52 1562250990.tar.gz
-rw-r--r-- 1 nagios nagios 4300876147 Jul 15 14:11 1563198890.tar.gz
-rw-r--r-- 1 nagios nagios 4316322270 Jul 17 14:33 1563372945.tar.gz
-rw-r--r-- 1 nagios nagios 4081553562 Jun  2 00:52 nagiosxi.1559431381.tar.gz
-rw-r--r-- 1 nagios nagios 4079481754 Jun  3 00:23 nagiosxi.1559517781.tar.gz
-rw-r--r-- 1 nagios nagios 4095356581 Jun  4 00:34 nagiosxi.1559604181.tar.gz
-rw-r--r-- 1 nagios nagios 4102117787 Jun  5 00:59 nagiosxi.1559690581.tar.gz
-rw-r--r-- 1 nagios nagios 4110617470 Jun  6 00:24 nagiosxi.1559776981.tar.gz
-rw-r--r-- 1 nagios nagios      11230 Jul 27  2017 tmp_xi_vars.cfg
The backup is setup to save the backup to this folder.
/mnt/nfs/backup/
Make sure it is mounted on the server and it is still writable be the nagios user.
Lets increase the backup timeout to an hour, edit this file
Add this to the bottom of that file
$cfg['backup_timeout'] = 3600;
Save the change and restart Apache and Nagios
service nagios restart
Wait until the next tine it runs and see if the backup completes.
dlukinski
Post by dlukinski »
tgriep wrote:The backup is setup to save the backup to this folder.
/mnt/nfs/backup/
Something is wrong:
- directory is writeable (manually initiated backups work)
- temp folder is created for scheduled backups with large files
- some backups from yesterday and a day before exist
- NO backups are listed under the "Local Backup Archive" aside from those initiated manually
Same errors for the scheduled backups as before
For this
What is the name of the temp folder that is created and what files are in them?
For this
What backups are you talking about? What are the names and folders are the files in?
For this
Those files are for the /store/backups/nagiosxi/. The scheduled backup file are in this folder /mnt/nfs/backup/ and will not be displayed.
