Setting up Oracle database Monitoring - facing issue
maxwellmiranda
we are facing issue while setting up Oracle monitoring plugin in Nagios XI.
we are getting following error
CRITICAL - cannot connect to dgdev1:1521. install_driver(Oracle) failed: Can't locate DBD/Oracle.pm in @INC (@INC contains: /usr/local/nagios/libexec /usr/lib/perl5/site_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site
this is a known error and it has been mentioned in the oracle plugin installation guide
we followed the instructions that were mentioned in the oracle plugin guide but that didnot fix the problem.
we are in the process of evaluating this product for our database and infrastructure monitoring. getting pass through this error is very important for evaluating this product.
can you help us in getting this fixed.
i am attaching the screenshot in the attachment with this support request.
we have installed the latest version of Nagios XI Nagios® Core™ 3.2.3 on the Linux OS
second request is how can i set up monitoring using our custom scripts. currently we use the wizard to set up monitoring.
Re: Setting up Oracle database Monitoring - facing issue
Did you add your LD_LIBRARY_PATH and ORACLE_HOME to the commands as the document describes?
When you ran this
Did CPAN say it was installed successfully?
When you ran this
export ORACLE_HOME=<path to your Oracle which was given by the script>
export LD_LIBRARY_PATH=$ORACLE_HOME/lib
cpan -i DBD::Oracle-
maxwellmiranda
it didnot complete successfully...i am attaching the output of the CPAN command in the word file.
I'm not an expert on this but it looks like it cannot connect to your ORACLE database...
Also I noted the following in the attached logs it is stating:
andRemember to actually *READ* the README file! Especially if you have any problems.
*** If you have problems...
read all the log printed above, and the README and README.help.txt files.
(Of course, you have read README by now anyway, haven't you?)
maxwellmiranda
i went through the readme files. however i did not find any valuable information that could resolve the issue that i am facing
maxwellmiranda
can you direct me to some documentation to setup oracle database monitoring.
This is the guide we have
http://assets.nagios.com/downloads/nagi ... lation.pdf
Have you tried running the plugin from the command line? Is this where you were seeing the error?
A would still guess the problem is that DBD::Oracle isn't installed correctly...
cd /usr/local/nagios/libexec
/usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client/lib ORACLE_HOME=/usr/lib/oracle/11.2/client /usr/local/nagios/libexec/check_oracle_health --connect "<SERVER_ADDRESS>:1521" --username <USERNAME> --password "<PASSWORD>" --mode connection-time --warning 1 --critical 5 -
maxwellmiranda
i have checked it from the command line.. i am getting the same error.
nagmon:/users/nagios> cd /usr/local/nagios/libexec
nagmon:/usr/local/nagios/libexec> /usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client/lib ORACLE_HOME=/usr/lib/oracle/11.2/client /usr/local/nagios/libexec/check_oracle_health --connect "dgdev1:1521" --username system --password "*****" --mode connection-time --warning 1 --critical 5
CRITICAL - cannot connect to dgdev1:1521. install_driver(Oracle) failed: Can't locate DBD/Oracle.pm in @INC (@INC contains: /usr/local/nagios/libexec /usr/lib/perl5/site_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl /usr/lib/perl5/5.8.8/i386-linux-thread-multi /usr/lib/perl5/5.8.8 .) at (eval 13) line 3.
Perhaps the DBD::Oracle perl module hasn't been fully installed,
or perhaps the capitalisation of 'Oracle' isn't right.
Available drivers: DBM, ExampleP, File, Gofer, Proxy, Sponge, mysql.
at /usr/local/nagios/libexec/check_oracle_health line 4755
i have referred to the same document as mentioned by you for the oracle plugin installation...even after setting up the environment variable..we are still facing the error
Lets do this
If it returns nothing, then it isn't installed and you will need to try again to install it from cpan.
One thing of note, the test's on your previous install show:
A little research on the Internet seems to point to not having set the ORACLE_SID environment variable.
where orcl is the database name (orcl is the default)
Once that is set you would need to run the cpan install again
locate Oracle.pmOne thing of note, the test's on your previous install show:
export ORACLE_SID=orclOnce that is set you would need to run the cpan install again
maxwellmiranda
the database i am monitoring is on a different server.
i have installed the oracle plugin on the nagios server.
do i still have to set the ORACLE_SID......
what would be the value for ORACLE_SID if want to monitor multiple ORACLE database on different servers
