can not access NagiosXI, DB error ...
xpertech
Post by xpertech »
We had transferred NagiosXI to Amazon AWS couple days and looks good, today when tried to login NagiosXI but it failed, after repaired DB then can login, but after logged in, the DB error page displayed, we tried to repaired DB again but still DB error.
How to let it back to normal?
xpertech
Re: can not access NagiosXI, DB error ...
Post by xpertech »
We installed new same version of NagiosXI on AWS, then restore the NagiosXI backed up file successful without error, after couple days we login again, it displayed DB error ?!
benjaminsmith
Post by benjaminsmith »
Hello @xpertech,
Please try running the following command to repair the database:
mysqlcheck -r -f -uroot -pnagiosxi --all-databases --use_frm
If the issue persists, please send us your system profile for us to review.
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share in a private message or upload it to the post/ticket, and then reply to this post to bring it up in the queue.
Thanks.
xpertech
Post by xpertech »
The command seems not work?! also can not get profile ...
benjaminsmith
Hello @xpertech,
It looks like the database is not running.
To check the status, on Cent 7, run the following:
systemctl status mariadb.service
To restart:
systemctl restart mariadb
