nsclient & nrpe configuration file changes
i have existing setup running with nagioscore. but now we would like to go with nagiosxi.
those servers are being monitored under nagioscore same will be monitored by nagiosxi.
we have deployed remote agent on monitoring devices e.g. nsclient on windows & nrpe agent on linux machine at the time of nagioscore installation.
as now we are going with nagiosxi, server ip and server will be change since which agent we have deployed on remote locations that remains same.
so can i use those exsiting nsclient & nrpe agent which are installed on remote machines.
do i need to do changes in nsclient & nrpe configuration files.
what can be done in such scenario. please share you views
thnx in advance.
thnx in advance.
Re: nsclient & nrpe configuration file changes
The NSClient++ shouldn't need to be changed unless you are using the NRPE features of it. If you are you will need to add the new IP address to the allowed_hosts field.
Also, for the Linux NRPE agents, the same, you will need to add the IP to the only_from section of /etc/xinetd.d/nrpe if they are running under xinetd or the allowed_hosts section of the nrpe.cfg if they are not.
added nagiosxi ip below configuration file
/etc/xinetd.d/nrpe
configure linux host in nagioxi but not able to monitor below error persist
CHECK_NRPE: Error - Could not complete SSL handshake.
/etc/xinetd.d/nrpe
Did you restart the daemon after you made changes in /etc/xinetd.d/nrpe?
Check if nrpe works fine on the client. If you had "127.0.0.1" added to the "only_from" section of "/etc/xinetd.d/nrpe", you could test NRPE on the client site by running:
You should see:
After you are sure it works on the client site, you can try running the check on the server site:
You should also see:
Make sure your firewall is not blocking the connection. Check if port 5666 is open - from a terminal on your Nagios server, you can try:
or
Hope this helps.
# service xinetd restartCode: Select all
# ./check_nrpe -H localhostCode: Select all
NRPE v2.12Code: Select all
# ./check_nrpe -H <client_IP>Code: Select all
nc -z <client_IP> 5666Code: Select all
telnet <client_IP> 5666Be sure to check out our Knowledgebase for helpful articles and solutions!
restrated service.
below error persist after run
#./check_nrpe -H localhost
-bash: ./check_nrpe: No such file or directory
below error i have got in nagiosxi dashboard
CHECK_NRPE: Socket timeout after 30 seconds.
Do you have nagios plugins installed on the client machine? Did you run this check from the plugins directory? On my machine I run:
Your path may be different or you may not have "check_nrpe" installed on the client.
Did you check if port 5666 is open?
cd /usr/local/nagios/libexec/
./check_nrpe -H localhostDid you check if port 5666 is open?
i have not installed any plugin on client machine
i have just made changes in /etc/xinet.d/nrpe file
after running below command on client machine:
CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for erro r messages.
#nc -z <client IP) 5666
Connection to <client ip>5666 port [tcp/nrpe] succeeded!
why i have not installed pluing on client machiens, is these servers are being monitored under nagios core,
now i have nagiosxi in place, and wants to add this server under nagiosxi.
OK, on your Nagios server, run the following commands in terminal:
Then on your client machine, run the following command in terminal and show us the output:
./check_nrpe -H 192.168.5.83 -t 30 -c check_procs -a '-w 200 -c 300'Code: Select all
tail /var/log/messagesBe sure to check out our Knowledgebase for helpful articles and solutions!
Client is machine is installed with redhat enterprise 5.7 tikanga
below are the logs:-
May 9 07:13:15 grpsgh311 xinetd[17522]: START: nrpe pid=15075 from=10.105.32.115
May 9 07:13:19 grpsgh311 xinetd[17522]: START: nrpe pid=15078 from=10.105.32.115
May 9 07:13:22 grpsgh311 xinetd[15079]: FAIL: nrpe address from=10.105.33.15
May 9 07:13:22 grpsgh311 xinetd[17522]: START: nrpe pid=15079 from=10.105.33.15
May 9 07:13:22 grpsgh311 xinetd[17522]: EXIT: nrpe status=0 pid=15079 duration=0(sec)
May 9 07:13:45 grpsgh311 nrpe[15075]: Could not read request from client, bailing out...
May 9 07:13:45 grpsgh311 xinetd[17522]: EXIT: nrpe status=0 pid=15075 duration=30(sec)
May 9 07:13:49 grpsgh311 nrpe[15078]: Could not read request from client, bailing out...
May 9 07:13:49 grpsgh311 xinetd[17522]: EXIT: nrpe status=0 pid=15078 duration=30(sec)
May 9 07:14:19 grpsgh311 xinetd[15107]: FAIL: nrpe address from=10.105.33.15
May 9 07:14:19 grpsgh311 xinetd[17522]: START: nrpe pid=15107 from=10.105.33.15
May 9 07:14:19 grpsgh311 xinetd[17522]: EXIT: nrpe status=0 pid=15107 duration=0(sec)
May 9 07:14:58 grpsgh311 xinetd[17522]: START: nrpe pid=15122 from=10.105.32.115
May 9 07:15:17 grpsgh311 xinetd[17522]: START: nrpe pid=15281 from=10.105.32.115
May 9 07:15:28 grpsgh311 nrpe[15122]: Could not read request from client, bailing out...
May 9 07:15:28 grpsgh311 xinetd[17522]: EXIT: nrpe status=0 pid=15122 duration=30(sec)
May 9 07:15:46 grpsgh311 xinetd[17522]: START: nrpe pid=15291 from=10.105.32.115
May 9 07:15:47 grpsgh311 nrpe[15281]: Could not read request from client, bailing out...
May 9 07:15:47 grpsgh311 xinetd[17522]: EXIT: nrpe status=0 pid=15281 duration=30(sec)
May 9 07:15:49 grpsgh311 xinetd[17522]: START: nrpe pid=15294 from=10.105.32.115
May 9 07:16:02 grpsgh311 xinetd[17522]: START: nrpe pid=15298 from=10.105.32.115
May 9 07:16:16 grpsgh311 nrpe[15291]: Could not read request from client, bailing out...
May 9 07:16:16 grpsgh311 xinetd[17522]: EXIT: nrpe status=0 pid=15291 duration=30(sec)
May 9 07:16:19 grpsgh311 nrpe[15294]: Could not read request from client, bailing out...
May 9 07:16:19 grpsgh311 xinetd[17522]: EXIT: nrpe status=0 pid=15294 duration=30(sec)
May 9 07:16:32 grpsgh311 nrpe[15298]: Could not read request from client, bailing out...
May 9 07:16:32 grpsgh311 xinetd[17522]: EXIT: nrpe status=0 pid=15298 duration=30(sec)
May 9 07:16:33 grpsgh311 xinetd[17522]: START: nrpe pid=15321 from=10.105.32.115
May 9 07:16:36 grpsgh311 xinetd[17522]: START: nrpe pid=15322 from=10.105.32.115
May 9 07:17:03 grpsgh311 nrpe[15321]: Could not read request from client, bailing out...
May 9 07:17:03 grpsgh311 xinetd[17522]: EXIT: nrpe status=0 pid=15321 duration=30(sec)
May 9 07:17:06 grpsgh311 nrpe[15322]: Could not read request from client, bailing out...
May 9 07:17:06 grpsgh311 xinetd[17522]: EXIT: nrpe status=0 pid=15322 duration=30(sec)
May 9 07:17:13 grpsgh311 xinetd[15337]: FAIL: nrpe address from=10.105.33.15
May 9 07:17:13 grpsgh311 xinetd[17522]: START: nrpe pid=15337 from=10.105.33.15
May 9 07:17:13 grpsgh311 xinetd[17522]: EXIT: nrpe status=0 pid=15337 duration=0(sec)
May 9 07:17:45 grpsgh311 xinetd[15344]: FAIL: nrpe address from=10.105.33.15
May 9 07:17:45 grpsgh311 xinetd[17522]: START: nrpe pid=15344 from=10.105.33.15
May 9 07:17:45 grpsgh311 xinetd[17522]: EXIT: nrpe status=0 pid=15344 duration=0(sec)
Try re-installing the linux agent on the client machine by following our documentation:
http://assets.nagios.com/downloads/nagi ... _Agent.pdf
