I am using Nagios Core and am looking for the plugin for bandwidth monitoring as well as a possible how to guide. as in what flatfiles do I put it in and where I put the command.
Newbie here.
Bandwith Monitoring
benjaminsmith
Re: Bandwith Monitoring
Hello @rsparks,
Typically, MRTG is used with Nagios to monitor bandwidth on a switch or router. I've included a few links below to help get you started, and let me know if you have any specific questions.
Graphing Performance Info With MRTG
The plugin check_rrdtraf can be configured to alert on incoming and outgoing levels.
check_rrdtraf
check_rrdtraf
