notification can not disabled?!
xpertech
Post by xpertech »
when tried to disable notification, it didn't work, what could be the problem?
Re: notification can not disabled?!
Perhaps the page didn't refresh? What happens when you go to a different page, then come back to this one? Do you see the red dot?
Is nagios and ndo2db running?
service nagios status
service ndo2db status
What is the output of the following command?
grep -A 35 programstatus /usr/local/nagios/var/status.dat | grep enable_notifications
Note: If you are using ramdisk, more probably you would need to run:
grep -A 35 programstatus /var/nagiosramdisk/status.dat | grep enable_notifications
If status.dat is in a different location, just use the correct path in the above command.
