having trouble using strings on return
gmills
Post by gmills »
Is there anything special Nagios configuration needs to support the command returning and accepting Strings?
I'm new, trying something new, and of course, struggling....
on command line, I can do ..
./check_jmx4perl --user passthru --password B@dC0mpany --url http://localhost:9090/jolokia --mbean org.apache.activemq:type=Broker,brokerName=amq,service=Health --attribute CurrentStatus --string --critical '!Good'
OK - [org.apache.activemq:type=Broker,brokerName=amq,service=Health,CurrentStatus] : 'Good' as expected
for Nagios monitorng server
Command.cfg
        command_name    check_local_container_broker_health
        command_line    $USER1$/check_jmx4perl --user $ARG1$ --password $ARG2$ --url $ARG3$ --mbean $ARG4$ --attribute $ARG5$ $ARG6$
Local Service def
        use                             local-service
        host_name                       localhost
        service_description             Container PassThru Broker Health
        check_command                   check_local_container_broker_health!passthru!B@dC0mpany!http://localhost:9090/jolokia!org.apache.activemq:type=Broker,brokerName=amq,service=Health!CurrentStatus!--string --critical '!Good'
** Handling check result for service 'Container Delta MRO Broker Health' on host 'localhost' from 'Core Worker 15854'...
[1562947372.677475] [016.1] [pid=15850] HOST: localhost, SERVICE: Container Delta MRO Broker Health, CHECK TYPE: Active, OPTIONS: 0, SCHEDULED: Yes, RESCHEDULE: Yes, EXITED OK: Yes, RETURN CODE: 1, OUTPUT: (No output on stdout) stderr: /bin/sh: -c: line 0: unexpected EOF while looking for matching `''
/bin/sh: -c: line 1: syntax error: unexpected end of file
However, nagios doesn't seem to understand or recognize Strings - I know it is either how I'm using it OR there is an option in need of enabling, if so, does this require recompiling ???
thank you again !!! I'm getting there :)
gmills
Re: having trouble using strings on return
Post by gmills »
I don't know if this is it, but it is working now, and a little confused.
I added another ARG to the command,
        command_line    $USER1$/check_jmx4perl --user $ARG1$ --password $ARG2$ --url $ARG3$ --mbean $ARG4$ --attribute $ARG5$ $ARG6$ $ARG7$
Yeilds:
[1562949146.077285] [016.0] [pid=12926] ** Handling check result for service 'Container Delta FADEC Broker Health' on host 'localhost' from 'Core Worker 12932'...
[1562949146.077306] [016.1] [pid=12926] HOST: localhost, SERVICE: Container Delta FADEC Broker Health, CHECK TYPE: Active, OPTIONS: 0, SCHEDULED: Yes, RESCHEDULE: Yes, EXITED OK: Yes, RETURN CODE: 0, OUTPUT: OK - [org.apache.activemq:type=Broker,brokerName=amq,service=Health,CurrentStatus] : 'Good' as expected
[1562949146.077336] [001.0] [pid=12926] get_service_check_return_code()
[1562949146.077370] [016.2] [pid=12926] Parsing check output...
[1562949146.077387] [016.2] [pid=12926] Short Output: OK - [org.apache.activemq:type=Broker,brokerName=amq,service=Health,CurrentStatus] : 'Good' as expected
The problem is that nagios used ! as an argument delimiter in the check_command field
you ended the command with
 --critical '!Good'
Which actually will split that into another $ARGn$
gmills
Post by gmills »
thank you
please excuse me, I'm an idiot sometimes :) this is probably another simple thing I'm just not getting, ...
how do I get around this? I did try adding another ARGn but this didn't work.
This command works on the Local Nagios Monitoring Server, but it like you mention, the NRPE server uses the ! char as a field delimiter.
I'm following the documentation as close as I can or know. but I do not know how to get around this. escaping \ doesn't work, I need the command to observe the ! in the String ARG as a NOT and not a delimiter.
I am observing from here that describes Strings but nothing talks about how this is to be interpreted on the NRPE side.
https://nagios-plugins.org/doc/guidelin ... HOLDFORMAT
https://metacpan.org/pod/release/ROLAND ... ng-checks
String checks
In addition to standard numerical checks, direct string comparison can be used. This mode is switched on either explicitely via --string (configuration: String) or by default implicitely if a heuristics determines that a value is non-numeric. Numeric checking can be enforced with the option --numeric (configuration: Numeric).
For string checks, --critical and --warning are not treated as numerical values but as string types. They are compared literally against the value retrieved and yield the corresponding Nagios status if matched. If the threshold is given with a leading !, the condition is negated. E.g. a --critical '!Running' returns CRITICAL if the value not equals to Running. Alternatively you can also use a regular expression by using qr/.../ as threshold value (substitute ... with the pattern to used for comparison). Boolean values are returned as true or false strings from the agent, so you can check for them as well with this kind of string comparison.
Does this apply to what i'm trying to do
# ILLEGAL OBJECT NAME CHARACTERS
# This option allows you to specify illegal characters that cannot
# be used in host names, service descriptions, or names of other
# object types.
# ILLEGAL MACRO OUTPUT CHARACTERS
# This option allows you to specify illegal characters that are
# stripped from macros before being used in notifications, event
# handlers, etc. This DOES NOT affect macros used in service or
# host check commands.
# The following macros are stripped of the characters you specify:
# $HOSTOUTPUT$
# $LONGHOSTOUTPUT$
# $HOSTPERFDATA$
# $HOSTACKAUTHOR$
# $HOSTACKCOMMENT$
# $SERVICEOUTPUT$
# $LONGSERVICEOUTPUT$
# $SERVICEPERFDATA$
# $SERVICEACKAUTHOR$
# $SERVICEACKCOMMENT$
# REGULAR EXPRESSION MATCHING
# takes place in the object config files. Regular expression
use_regexp_matching=0
Have you tried placing '!Good' in the resource.cfg file? You can create a user macro ($USERx$), which can be passed to your command. This could solve the issue with the "!", being a delimiter.
gmills
Post by gmills »
did I do this correctly?
because I'm stil getting the same result.
[1562969268] Host 3.239.245.209 is asking for command 'check_remote_container_broker_health' to be run...
[1562969268] Running command: /usr/local/nagios/libexec/check_jmx4perl --user deltafadec --password B@dM0nk3y --url http://localhost:9093/jolokia --mbean org.apache.activemq:type=Broker,brokerName=amq,service=Health --attribute CurrentStatus --string --critical Good
[1562969268] Command completed with return code 2 and output: CRITICAL - [org.apache.activemq:type=Broker,brokerName=amq,service=Health,CurrentStatus] : 'Good' matches threshold 'Good'
[1562969268] Return Code: 2, Output: CRITICAL - [org.apache.activemq:type=Broker,brokerName=amq,service=Health,CurrentStatus] : 'Good' matches threshold 'Good'
[1562969268] Connection from 3.239.245.209 closed.
what I did
        host_name                       alphprdfuse1i
        service_description             Container Delta FADEC Broker Health
        check_command                   check_nrpe!check_remote_container_broker_health!-a '--user deltafadec --password B@dM0nk3y --url http://localhost:9093/jolokia --mbean org.apache.activemq:type=Broker,brokerName=amq,service=Health --attribute CurrentStatus --string --critical [b]$USER3$[/b]'
resource.cfg
$USER3$='!Good'
the nagios daemons have been recycled both nagios and nrpe
gmills
Post by gmills »
Hello, happy Monday :)
I am wondering - the problem I am having is that passing arguments to NRPE and evaluating as String.
The String evaluation has a Logical NOT operator in it. I guess this is the problem. So, the actual question should be, how do we get String operations on NRPE to work, using operators like NOT AND OR Greator, Lessthan, etc... without effecting the normal processing of fields.
check_command                   check_nrpe!check_remote_container_broker_health!-a '--user iprcmtx --password G00gl3M3 --url http://localhost:9091/jolokia --mbean org.apache.activemq:type=Broker,brokerName=amq,service=Health --attribute CurrentStatus --string --critical '!Good''
so, this is passing all the args, it gets the --string --critical '!Good' that needs to be evaluated as IF NOT EQUAL to GOOD, where it is getting evaluated as splitting the argument '!Good' as separate fields. ??? thank you.
Can you click on the "Container Delta FADEC Broker Health" service in the GUI, then click on the "Re-schedule the next check of this service" link under the "Service Commands" section, and show a screenshot of the page?
gmills
Post by gmills »
I'm sorry, I don't know how to paste or post an image, can you kindly explain how to do this? thank you
I can't just cut and paste an image. thank you
Nagios UI Shot
Nagios UI Shot
Take the screenshot with whatever program is available on your system, and save the file. Then you go to: Upload attachment > Browse... > <your screenshot> > Add the file > Place inline
