The WatchGuard plugin
ruffsense
Post by ruffsense »
Can i monitor vpn tunnels with it. Because it does not find them.
I found this: http://www.oidview.com/mibs/3097/WATCHG ... L-MIB.html
I don't insult, I diagnose.
Re: The WatchGuard plugin
What is the Make and Model number of the WatchGuard device?
Have you created any commands and service checks in Nagios XI already?
If so, can you post them so we can view them?
Is the device enabled for SNMP?
What sort of errors are you getting and it you are receiving any data, what is it?
ruffsense
Post by ruffsense »
tgriep wrote:What is the Make and Model number of the WatchGuard device?
Model 4600.
But the watchguard check does not get the tunnels. You really need the mibs i posted.
It only get interfaces and vlans. Memory does kinda stuff.
The WatchGuard Wizard in XI does not support the reading of the VPN tunnel status, so that is why they are not there.
To get then, you would have to upload the MIB file to the XI server and use the SNMP Walk wizard and create the checks from there.
To upload the MIB file for the device.
Go to the Admin > Manage MIBs menu, browse for the MIB and check the upload it there.
Then run the SNMPWalk wizard, select the OID's you want to monitor.
ruffsense
Post by ruffsense »
tgriep wrote:The WatchGuard Wizard in XI does not support the reading of the VPN tunnel status, so that is why they are not there.
Thank you for the fast support. This can now be closed.
