openmanage issue:CHECK_NRPE: Received 0 bytes from daemon
simbu991
Post by simbu991 »
Hi Team,
we are monitoring the dell hardware status via check_manage plugin on some of the physical servers.
we could see some of the servers ,facing the issue while monitoring dell hardware plugin for certain time and received below alert.
[root@xxxx libexec]# ./check_nrpe -H xxxxxxxx -c check_openmanage -t 120
CHECK_NRPE: Received 0 bytes from daemon.  Check the remote server logs for error messages.
while checking the nsclient logs from the server end , the following error reported
2019-07-16 13:29:28: error:c:\source\master\include\socket/connection.hpp:139: Socket was unexpectedly closed trying to send data (possibly check your timeout settings)
I have tried to change the timeout settings .ini file as well and it's couldn't help . could you please assist to resolve the issue.
Regards,
Simbu
benjaminsmith
Re: openmanage issue:CHECK_NRPE: Received 0 bytes from daemo
Post by benjaminsmith »
Hi Simbu,
Probably a network issue as some of your servers are working and some are not. What version of NSClient++ are you using and what are the timeout settings in the nsclient.ini file?
For example,
[settings/NPRE/server]
timeout = 70
It would be helpful if you could upload the nsclient.ini and nsclient.log file for us to review? Thanks.
simbu991
Post by simbu991 »
Hi benjaminsmith,
Thanks for the clarity. I am using Nsclient++ 0.52 version. please find the attached ini file for review.
Regards,
Simbu S
nsclient.ini
Nsclient config
(12.33 KiB) Downloaded 204 times
Couple of things to try.
Edit the nsclient.ini file and change this option from
extended response = false
to
extended response = true
in case the plugin's output is large, this should allow the nrpe plugin to read it all.
Your check_openmanage command is hard coded to not accept arguments so change this from
check_openmanage = scripts/check_openmanage.exe
to
check_openmanage = scripts/check_openmanage.exe $ARG1$
Change this in the default section from
timeout = 30
to
timeout = 60
Save the changes and restart NSCLient++
To pass arguments using the check_nrpe plugin, you need to add the -a option and the data to send to the agent so run this example command on the nagios server.
./check_nrpe -H xxxxxxxx -c check_openmanage -a '-t 60'
simbu991
Post by simbu991 »
Hi tgriep,
Thank you for the reply.
I have modified the respective parameters as suggested, but still am getting time out error.
[root@INFSGDCNGOS03 libexec]# ./check_nrpe -H 10.180.12.85 -c check_openmanage -a -t 60
CHECK_NRPE: Socket timeout after 10 seconds.
Please advise.
Regards,
Simbu
When specifying an argument with the check_nrpe plugin, you need to wrap them in single quotes like this.
./check_nrpe -H 10.180.12.85 -c check_openmanage -a '-t 60'
Do you see any errors in the C:\Program Files\NSClient++\nsclient.log file when the check is ran?
Can you run the check_openmanage.exe executable on the remote server without any errors?
http://folk.uio.no/trondham/software/ch ... anage.html
simbu991
Post by simbu991 »
Hi Tgrief,
I have tried with quotes and getting the same error.
[root@INFSGDCNGOS03 libexec]# ./check_nrpe -H xxxxx -c check_openmanage -a '-t 60'
please find the output of nsclient.log file from client end.
2019-07-23 16:15:55: error:c:\source\master\include\socket/connection.hpp:139: Socket was unexpectedly closed trying to send data (possibly check your timeout settings)
2019-07-23 16:17:54: error:c:\source\master\include\socket/connection.hpp:139: Socket was unexpectedly closed trying to send data (possibly check your timeout settings)
Regards,
Simbu
Can you run the check_openmanage.exe executable on the remote server to see if it runs?
If it does run, how long does it take to run in seconds?
