I am trying to setup Nagios to monitor my infra.
When trying to install the Nagios agent getting error. Please help to fix this.
Installation log attached for your reference.
Thanks in advance.
Nagios agent INSTALLATION ERROR!
ssabuthagir
Re: Nagios agent INSTALLATION ERROR!
It looks like you have repositories that are trying to install i686 RPM's on a x86_64 systemCode: Select all
---> Package keyutils-libs.i686 0:1.4-4.el6 will be installed ---> Package libselinux.i686 0:2.0.94-5.3.el6 will be installed ---> Package libsepol-devel.x86_64 0:2.0.41-4.el6 will be installed
You need to correct the system repositories
