PerfData not processed
P201420
Post by P201420 »
I deleted old files and directory no longer monitored
/usr/local/nagios/share/perfdata/
I left all the currently monitored dir/files
So Im sure I broke this...
Linux - vm- 64
installed Jan 2019
Version 5.6.4
Ramdisk install Jan 2019
Issue started today
File count growing on ramdisk perfdata - not being processed. No perfdata at all showing, worked earlier today.
rebooted
restarted various services, check manual ramdisk setup to validate paths have not changed.
turned on debug to 2
vi /usr/local/nagios/etc/pnp/process_perfdata.cfg
2019-07-16 14:14:42 [26637] [2] Using Config File /usr/local/nagios/etc/pnp/process_perfdata.cfg parameters
2019-07-16 14:14:43 [26635] [1] process_perfdata.pl-0.6.11 starting in BULK Mode called by NPCD
2019-07-16 14:14:43 [26635] [2] searching for /var/nagiosramdisk/spool/perfdata//host-perfdata.1563286475
2019-07-16 14:14:43 [26635] [2] renaming /var/nagiosramdisk/spool/perfdata//host-perfdata.1563286475 to /var/nagiosramdisk/spool/perfdata//host-perfdat.1563286475-PID-26635 for bulk update
2019-07-16 14:14:43 [26635] [2] reading /var/nagiosramdisk/spool/perfdata//host-perfdata.1563286475-PID-26635 for bulk update
2019-07-16 14:14:43 [26635] [2] Processing Line 1
2019-07-16 14:14:43 [26635] [2] Datatype set to 'HOSTPERFDATA'
2019-07-16 14:14:43 [26635] [1] Found Performance Data for ny17u3094 / _HOST_ (rta=0.196ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=0.640ms;;;; rtmin=.078ms;;;;)
2019-07-16 14:14:43 [26635] [2] No Custom Template found for check_xi_host_ping (/usr/local/nagios/etc/pnp/check_commands/check_xi_host_ping.cfg)
2019-07-16 14:14:43 [26635] [2] Template is check_xi_host_ping.php
2019-07-16 14:14:43 [26635] [2] data2rrd called
2019-07-16 14:14:43 [26637] [1] process_perfdata.pl-0.6.11 starting in BULK Mode called by NPCD
2019-07-16 14:14:43 [26637] [2] searching for /var/nagiosramdisk/spool/perfdata//service-perfdata.1563286474
2019-07-16 14:14:43 [26637] [2] renaming /var/nagiosramdisk/spool/perfdata//service-perfdata.1563286474 to /var/nagiosramdisk/spool/perfdata//service-prfdata.1563286474-PID-26637 for bulk update
2019-07-16 14:14:43 [26637] [2] reading /var/nagiosramdisk/spool/perfdata//service-perfdata.1563286474-PID-26637 for bulk update
2019-07-16 14:14:43 [26637] [2] Processing Line 1
2019-07-16 14:14:43 [26637] [2] Datatype set to 'SERVICEPERFDATA'
2019-07-16 14:14:43 [26637] [1] Found Performance Data for nl85w1060 / WINTEL-Core-CPU ('percent'=6.25%;90;100;)
2019-07-16 14:14:43 [26637] [2] No Custom Template found for check_xi_ncpa (/usr/local/nagios/etc/pnp/check_commands/check_xi_ncpa.cfg)
2019-07-16 14:14:43 [26637] [2] Template is check_xi_ncpa.php
2019-07-16 14:14:43 [26637] [2] data2rrd called
benjaminsmith
Re: PerfData not processed
Post by benjaminsmith »
When did the Nagios server stop processing peformance graphs? Was this before or after making changes to the pefdata directory?
Can you send your system profile for us to review? Thanks.
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share in a private message or upload it to the post/ticket, and then reply to this post to bring it up in the queue.
P201420
Post by P201420 »
Hello
if was afterward. The graph link disappeared for everything.
I had turned performance data checks off after this post for fear of filling the ramdisk/perfdata, and went on to other work.
After a couple of hours I noticed the graph link was back and when selected showed the history.
Turned the perf checks back on and everything was processing again.
All is well.
Dont understand what happened or why but you can close this, unless you would like some other infor....
benjaminsmith
Thanks for the update. The files may have spooled up temporarily after deleting the old files, and delayed the processing of performance data.
Anyhow, happy to hear it's working again.
I'll go ahead a close this thread, but feel free to open another if you have any new questions.
