XI local backups not running
rferebee
Post by rferebee »
Hello, are there any logs for local backups? I noticed that the backup that is supposed to occur nightly on my XI server hasn't been happening for the last 5 days, but the GUI says it ran last night.
benjaminsmith
Re: XI local backups not running
Post by benjaminsmith »
Hi @rferebee
The log file for scheduled backups is located in /usr/local/nagiosxi/var/components/scheduledbackups.log.
Also take a look a the subsystem log for any errors.
/usr/local/nagiosxi/var/cmdsubsys.log
Let us know if you get it worked out.
Reference:
Nagios XI Log File and Descriptions
rferebee
Post by rferebee »
It looks like it's a SQL issue. I ran a repair. I'll let you know tomorrow morning if the backup runs tonight.
Thank you.
benjaminsmith
Thanks for the update and let me know if you get it running again.
rferebee
Post by rferebee »
Looks like everything is working properly now.
I notice we have a lot of DB issues on a monthly basis. Is there anything we can do to prevent these issues? We have a DB repair script that runs every Thursday, but it doesn't seem to help. All I did to fix this latest problem was to run the DB repair manually and also I ran another script that was provided by you folks. See below for examples:
Built in SQL repair script: /usr/local/nagiosxi/scripts/repairmysql.sh nagios
Command provided by Nagios: mysqlcheck -r -f -uroot -pnagiosxi --all-databases --use_frm
Should we only be using one of these versus the other?
benjaminsmith
Hello @rferebee,
I would recommend using the built in database repair script. The only difference between the two is the --use-frm option. In some cases, it's necessary to re-create the .MYI index file to repair the database.
Let's check the size of your database tables. Open up a terminal run the following command, and post the full output.
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --tab
rferebee
Post by rferebee »
Here's what I got:
[root@nagiosxi ~]# echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --tab
ERROR 2003 (HY000): Can't connect to MySQL server on '127.0.0.1' (111)
I could be wrong, but I think we're using PostgreSQL not MySQL.
benjaminsmith
Hi @rferebee,
Ok, let's check that by running the following command:
grep mysql /usr/local/nagiosxi/html/config.inc.php | wc -l
If it outputs the number 2, you have postgres and run the following command and post the full output:
echo "SELECT relname as Table, pg_size_pretty(pg_total_relation_size(relid)) As Size, pg_size_pretty(pg_total_relation_size(relid) - pg_relation_size(relid)) as ExternalSize FROM pg_catalog.pg_statio_user_tables ORDER BY pg_total_relation_size(relid) DESC;" | psql nagiosxi nagiosxi
rferebee
Post by rferebee »
Yup, looks like it's Postgre
Here's the output:
[root@nagiosxi ~]# echo "SELECT relname as Table, pg_size_pretty(pg_total_relation_size(relid)) As Size, pg_size_pretty(pg_total_relation_size(relid) - pg_relation_size(relid)) as ExternalSize FROM pg_catalog.pg_statio_user_tables ORDER BY pg_total_relation_size(relid) DESC;" | psql nagiosxi nagiosxi
table | size | externalsize
xi_meta | 8208 kB | 1256 kB
xi_auditlog | 3048 kB | 1896 kB
xi_usermeta | 2408 kB | 1488 kB
xi_events | 744 kB | 576 kB
xi_options | 160 kB | 120 kB
xi_users | 128 kB | 72 kB
xi_commands | 112 kB | 96 kB
xi_sysstat | 96 kB | 72 kB
xi_mibs | 72 kB | 64 kB
xi_sessions | 56 kB | 48 kB
xi_auth_tokens | 40 kB | 40 kB
xi_eventqueue | 32 kB | 24 kB
xi_cmp_trapdata | 24 kB | 24 kB
xi_cmp_trapdata_log | 16 kB | 16 kB
xi_incidents | 8192 bytes | 8192 bytes
(15 rows)
benjaminsmith
Ok. Thanks. The last output looks normal.
There are two other databases on the system, are you able to get the table sizes with this command?
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --tab
Also, take a look at the following guide, and if possible, you can improve performance reducing data retention values.
Nagios XI Database Optimization
