To test if the log server was working I added the nagios server as a host, now I get all my logs for the localhost in double and can't figure out how to delete the double.
I used the scripts to install so everything is as the "default" installation scripts are configured.
Any help would be greatly appreciated.
Deleting host
Deleting host
Re: Deleting host
the following should remove it
rm -f /etc/rsyslog.d/99-nagioslogserver.conf
systemctl restart rsyslogRe: Deleting host
That seems to have taken care of it!
Unsurprisingly the old logs are still available, is there a way to only delete the logs of that one server ?
EDIT: I figured that, in my case, since I just started I would simply edit the "Snapshots & Maintenance" option "Delete indexes older than" to 1 so that I will simply have to wait until tomorrow for the unwanted logs to be deleted and reset the delete option afterwards.
Re: Deleting host
Another option would be to run a query like this:
Where IP is the IP address of the host the records came from.
curl -XDELETE 'http://localhost:9200/logstash-*/_query?q=host:IP'As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Re: Deleting host
Corrected. Thanks!
