RAM memory monitoring information is not real
parboleda
Post by parboleda »
Hello everyone I use Nagios XI to monitor a centos server, the monitoring was configured with "ncpa", in RAM does not show the real value of the used memory, shows that the total of ram is 16 Gb that is correct, the The value of the available memory is also correct, but in the used memory it shows only 1.68 Gb, when in fact it is using almost 16 Gb, and it is not generating alerts to me because it is consuming all the memory, how can I make it show the information Real and send alerts?
Re: RAM memory monitoring information is not real
You have 12006 cached which is subtracted out because that will be free'd on demand
Free = Total - Used - Cached
parboleda
Post by parboleda »
Good morning, thanks for the answer, it is not very clear to me, if rest those values ​​gives a negative value
Free = 16000 - 15600 - 12006
free = -11606
Is there a way for Nagios to ignore the cache value?
NCPA uses psutils to calculate the memory, here are the docs
https://psutil.readthedocs.io/en/latest/#memory
parboleda wrote:Is there a way for Nagios to ignore the cache value?
Not with NCPA, but There are other memory plugins available on the Nagios exchange
http://exchange.nagios.org/
parboleda
Post by parboleda »
Good afternoon, thanks for the information, there is some other recommended method different to NCPA to monitor the memory that throws the values ​​that I need and that is not very complex to configure
ssax
Dreams In Code
Post by ssax »
I think you could probably use this:
https://support.nagios.com/kb/article.php?id=171
parboleda
Post by parboleda »
Thanks for the information
mbellerue
Post by mbellerue »
Do you have any other questions, or can I close this thread?
