Tooltip Field - GUI display
SteveBeauchemin
Post by SteveBeauchemin »
Is there any way to pull the tooltip information out in front of the other screen data?
Please see attachments... Pick the one you like best.
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
ssax
Dreams In Code
Re: Tooltip Field - GUI display
Post by ssax »
I am able to replicate this as a bug, the z-index (css attribute) is being set lower than it should and is likely a bug in the bettermap component, I will report it to the devs and see if I can find a workaround.
