Upgrade to 5.6.5 said it failed but it didn't, kind of
jbpatric
Post by jbpatric »
Related to another post of mine, "Upgrade to 5.6.4 said it failed but it didn't". Opening a new post because that one was locked.
Upgraded to 5.6.5 this morning and had the same problem when I upgraded to 5.6.4. Started the upgrade to 5.6.5 from the Admin-Check For Updates screen. When it finished it returned a message that the update failed and I should update Nagios manually. Even though it is telling me the server is running 5.6.5 the server is still reporting I need to upgrade to to 5.6.5. See the attached screen shot,
But, the site is reporting I am running 5.6.5.
Luckily I copied the upgrade text before refreshing the pages because the Update History at the bottom of the Check For Updates page doesn't have an entry for today's upgrade.
Here's the upgrade output...
---- Starting Nagios XI Backup ----
No entry for terminal type "unknown";
using dumb terminal settings.
Backing up Nagios Core...
tar: Removing leading `/' from member names
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var/ndo.sock: socket ignored
tar: /usr/local/nagios/var: file changed as we read it
Backing up Nagios XI...
tar: /usr/local/nagiosxi/var/sysstat.log: file changed as we read it
tar: /usr/local/nagiosxi/var/eventman.log: file changed as we read it
tar: /usr/local/nagiosxi/var: file changed as we read it
Backing up MRTG...
Backing up the SNMP directories
Backing up NRDP...
Backing up Nagvis...
Backing up nagios user home dir...
Backing up MySQL databases...
Backing up cronjobs for Apache...
Backing up logrotate config files...
Backing up Apache config files...
Compressing backup...
BACKUP COMPLETE
Backup stored in /store/backups/nagiosxi/autoupgrade_backup.1563542565.tar.gz
---- Starting Nagios XI Upgrade ----
Cleaning up temp directory...
Nagios XI Upgrade Log
DATE: Fri Jul 19 09:26:18 EDT 2019
DISTRO INFO:
CentOS
7.6.1810
x86_64
Archive: sourceguardian/ixed4.lin.x86-64.zip
inflating: /usr/lib64/php/modules/ixed.5.4.lin
Sourceguardian extension found for PHP version 5.4
Sourceguardian extension already in php.ini
Checking required prereqs...
Please wait...
OLD VERSION: 5604
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirror.fileplanet.com
* epel: mirror.steadfastnet.com
* extras: ftp.ussg.iu.edu
* updates: ftp.ussg.iu.edu
No packages marked for update
Examining /usr/local/nagiosxi/tmp/nagiosxi/nagiosxi-deps-el7-5.6.5-1.noarch.rpm: nagiosxi-deps-el7-5.6.5-1.noarch
Marking /usr/local/nagiosxi/tmp/nagiosxi/nagiosxi-deps-el7-5.6.5-1.noarch.rpm as an update to nagiosxi-deps-el7-5.6.4-1.noarch
Resolving Dependencies
--> Running transaction check
---> Package nagiosxi-deps-el7.noarch 0:5.6.4-1 will be updated
---> Package nagiosxi-deps-el7.noarch 0:5.6.5-1 will be an update
Dependencies Resolved
Package Arch Version Repository Size
Updating:
nagiosxi-deps-el7 noarch 5.6.5-1 /nagiosxi-deps-el7-5.6.5-1.noarch 0.0
Transaction Summary
Upgrade 1 Package
Downloading packages:
Running transaction test
Transaction test succeeded
Running transaction
Updating : nagiosxi-deps-el7-5.6.5-1.noarch 1/2
Cleanup : nagiosxi-deps-el7-5.6.4-1.noarch 2/2
Verifying : nagiosxi-deps-el7-5.6.5-1.noarch 1/2
Verifying : nagiosxi-deps-el7-5.6.4-1.noarch 2/2
Updated:
Complete!
UPGRADE: NRDP is being upgraded...
UPGRADE: NRDP upgraded OK.
no crontab for nagios
no crontab for root
Copying over new XI directory...
Patching NDOUtils...
NDOUtils already patched at level 103
Installing new PNP templates...
Enabling large install tweaks...
Fixing config file permissions...
chown: cannot access ‘/var/www/html/nagiosql/config’: No such file or directory
Fixing htpasswd permissions...
Checking group memberships...
Installing new XI templates...
--- reset_config_perms.sh ------------
> Setting script permissions
> Setting CCM script permissions
> Setting special script permissions
> Setting special component script permissions
> Setting configuration file/directory permissions
> Setting perfdata directory and RRD permissions
> Setting libexec directory permissions
> Setting Nagios XI config permissions
> Setting NOM checkpoint user:group permissions
> + Setting Nagios Core corelog.newobjects user:group permissions
> + Setting CCM configuration file user:group permissions
> + Setting Recurring Downtime file user:group permissions
> + Setting BPI configuration file user:group permissions
--- ccm_import.php -------------------
> Setting import directory: /usr/local/nagios/etc/import/
> Importing config files into the CCM
- Importing: /usr/local/nagios/etc/import/xi_timeperiod_24x7.cfg .. SUCCESS
--- ccm_export.php -------------------
> Writing CCM configuration to Nagios files
Finished writing out configuraton
> Verifying configuration with Nagios Core
> Output:
Nagios Core 4.4.3
Last Modified: 2019-01-15
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for timeperiod 'xi_timeperiod_24x7' (config file '/usr/local/nagios/etc/timeperiods.cfg', starting on line 472)
Error: Could not add object property in file '/usr/local/nagios/etc/timeperiods.cfg' on line 476.
directives and data definitions. If you are upgrading from a previous
> Return Code: 1
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /usr/local/nagiosxi/scripts
LATEST NOM SNAPSHOT: /usr/local/nagiosxi/nom/checkpoints/nagioscore/1563507243.tar.gz
/ /usr/local/nagiosxi/scripts
RESTORING NOM SNAPSHOT : /usr/local/nagiosxi/nom/checkpoints/nagioscore/1563507243.tar.gz
Sames error I received that last upgrade...
So, last time this happened, as suggested, I deleted the config files, recreated and verified. But, to get the verify to work I had to remove the Template Name entry in the xi_timeperiod_24x7 time period. See the attached screen shot for what it looked like before I cleared the Template Name line,
. After removing that entry I successfully ran a verify files in config management. So, I know the template line was blank before attempting the upgrade today but it appears to have been added back during the upgrade. The upgrade process must add that line back in, but adding that back caused the upgrade to fail.
Re: Upgrade to 5.6.5 said it failed but it didn't, kind of
If the same issue happens on the next upgrade, check to see if the 'xi_timeperiod_24x7' is defined somewhere in the /usr/local/nagios/etc/static/ directory. You will hit a "duplicate definition" error if the template is defined in both places - in the static and in the database (CCM). Since nagios adds the template in the CCM, it would make sense to remove it from the static next time, so that you won't have to deal with this on every upgrade.
jbpatric
Post by jbpatric »
Went ahead a looked through these files in that directory, xiobjects.cfg xitemplates.cfg xitest.cfg, and there was an entry for 'xi_timeperiod_24x7'. I will look again when running the next upgrade.
mbellerue
Post by mbellerue »
Is it alright if we mark this as closed?
jbpatric
Post by jbpatric »
Please keep this open until the next update comes out.
benjaminsmith
Post by benjaminsmith »
Sounds good. We'll keep it open.
