Error while installing Nagios XI
anchitnarayan
Post by anchitnarayan »
While i was trying to install Nagios XI, the fullinstall script gave error. It gave error in the pre-requisites installation steps.
There was an option to --skip-broken, but it is not working.
I have attached the log files as well.
cdienger
Re: Error while installing Nagios XI
Post by cdienger »
Enable the optional repo:
https://support.nagios.com/kb/article/e ... s-155.html
and then try install the packages with this command:
yum install php-devel php-snmp php-mbstring
