NCPA Agent on RHEL, HTTP 403 FORBIDDEN
Guyver1
Post by Guyver1 »
I've just installed the NCPA agent on a RHEL 7 server and configured it as per all my other NCPA agent based servers.
However when doing my initial check i get the following:
[root@nagios libexec]# ./check_ncpa.py -H 192.168.xxx.xxx -t 'notmyrealtoken' -P 5693 -M 'system/agent_version' -v
Connecting to: https://192.168.xxx.xxx:5693/api/system ... en&check=1
An error occurred:HTTP Error 403: FORBIDDEN
I have also tried the web interface for the agent and get the same error:
Forbidden
You don't have the permission to access the requested resource. It is either read-protected or not readable by the server.
When attempting to add port 5693 to the firewall it tells me the firewall is not running so is not an issue:
[root@hostname ~]# firewall-cmd --add-port=5693/tcp --permanent
FirewallD is not running
How do I get this working?
benjaminsmith
Re: NCPA Agent on RHEL, HTTP 403 FORBIDDEN
Post by benjaminsmith »
Hello @Guyver1,
Find the ncpa.cfg file and change the following line:
ip = ::
To:
ip = 0.0.0.0
Save the changes and re-start the NCPA listener and then test again. Let me know if the issue is resolved for you.
service ncpa_listener restart
Guyver1
Post by Guyver1 »
Amazing! Thank you very much!
I knew it was something simple!
I've added that to my notes.
Cheers.
Great!
Locking
