Dear XI Team:
I am findind the following PHP warning in my /var/log/httpd/error_log very 5 seconds when I am logged in into XI and the Home Dashboard is open
[Fri Apr 13 21:19:29 2012] [error] [client 188.193.38.219] PHP Warning: Division by zero in /usr/local/nagiosxi/html/includes/components/xicore/ajaxhelpers-sysstat.inc.php on line 113, referer: http://h1997468.stratoserver.net/nagios ... ain.php?&=
Apart from the error message the system is running fine.
Klaus.
PHP Warning
Re: PHP Warning
In fact it is 2 PHP Warnings each time from different lines in the specific php file:
[Fri Apr 13 21:56:30 2012] [error] [client 188.193.38.219] PHP Warning: Division by zero in /usr/local/nagiosxi/html/includes/components/xicore/ajaxhelpers-sysstat.inc.php on line 111, referer: http://h1997468.stratoserver.net/nagios ... ain.php?&=
[Fri Apr 13 21:56:30 2012] [error] [client 188.193.38.219] PHP Warning: Division by zero in /usr/local/nagiosxi/html/includes/components/xicore/ajaxhelpers-sysstat.inc.php on line 113, referer: http://h1997468.stratoserver.net/nagios ... ain.php?&=
Re: PHP Warning
Does this machine have 0 swap memory?
Re: PHP Warning
Correct, yes, 0 (zero) swap memory. I dont need it currently, RAM is 2 GB and usage is 200-300 MB, with no other user service running on the system. performance is ideal.
Re: PHP Warning
Ype, the Server Statistics Dashlet is assuming there is some swap. This is an assumption the software really shouldn't make, I will put this on the list of items to be modified.
Until this fix gets into the mix, if you want to stop the errors, if you allocate a couple kb to swap you will no longer have the division by zero.
Re: PHP Warning
Fine for me and issue can be closed on that basis.
Many thanks again!
Many thanks again!
