Unknown error
manimurugesan
Unknown error
Post by manimurugesan »
Hello Team,
We are monitoring windows automatic services using external script power shell script via NRPE but we are getting unknown error for this service
could you please suggest for this
cdienger
Re: Unknown error
Post by cdienger »
What is the full command that this check is running? What is returned if you run the powershell script directly on the Windows machine? Do you have a link to the powershell script?
manimurugesan
Re: Unknown error
Thanks for your response .
The below issue has been resolved now :D .
mbellerue
Re: Unknown error
Post by mbellerue »
Glad to hear everything is working now!
