Deleted rrd returns?
BanditBBS
Post by BanditBBS »
I'm trying to delete an rrd and associated xml file so it gets recreated on next check. I delete the files and they are being recreated with all the old data! I know I've deleted an rrd file to start it over in the past, but its just coming right back!
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
cdienger
Re: Deleted rrd returns?
Post by cdienger »
Is this a standalone machine or do you have any scripts in place to replicate configs and files between this machine and another? The only thing that comes to mind that would explain why the old data is getting inserted back in would be a if a old copy is getting moved over.
BanditBBS
Post by BanditBBS »
Nothing for replication, this server is just a NagiosXI box. Just so confusing how it is coming back every time.
cdienger
Post by cdienger »
Very strange. Exactly what steps are you taking? You're deleting the files found at /usr/local/nagios/share/perfdata/<hostname>/<servicedesc>.[rrd|xml] correct? Is the recreated rrd file the same size as the deleted one? Are you checking the data inside it with rrdtool? For example:
rrdtool dump /usr/local/nagios/share/perfdata/hostnameA/ServiceA.rrd
