Hi, I'm looking for audit logs or access logs similar to the ones detailed in these Nagios XI videos:
https://www.youtube.com/watch?v=diDDm3BTQoQ
Where are these raw log files located? I've read the documentation here without having much luck: https://assets.nagios.com/downloads/nag ... ptions.pdf
Thanks in advance!
Where to find "audit logs" or "access logs"?
Re: Where to find "audit logs" or "access logs"?
Think I figured this out myself.
On the Admin screen, go to: System Settings
Then check...
[X] Write Audit Log to file: When checked all audit log events will be written to /usr/local/nagiosxi/var/components/auditlog.log
Then check...
Thanks for posting the solution!
